Inventor VBA Part Center Point
I am hoping somebody can help me with this VBA sub.
I want to look through a large assembly model and pick out the parts based upon their node names (got that far)
Then I want to extract the X , Y , Z values of that parts origin (or center point as it's labeled in the feature tree)
so I can use them in a string:
Public Sub TP_POINTS1()
    Dim qty As Integer
    qty = 1
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition
    Set oAsmDef = oAsmDoc.ComponentDefinition
  ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
    Set oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
  ' Iterate through the occurrences and print the name.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
        'select only the parts that have the correct name
        Dim oName As String
        Dim strOrig As String
        Dim leftstring As String
        strOrig = oOcc.name
        leftstring = Left(strOrig, InStr(strOrig, ":"))
        oName = Right(leftstring, 5)
        If oName = "(TP):" Then
            qty = qty + 1
    Next
End Sub
marcin_otręba
you want x,y,z values but in assembly coordinates?
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Yes. that's right.
ekinsb
Here's a modified version of your program that I believe does what you want.  I've tried to explain what it's doing in the comments but I know that it might be a little hard to understand.
Public Sub GetOriginPoints()
    Set oLeafOccs = oAsmDef.occurrences.AllLeafOccurrences
        strOrig = oOcc.Name
        Dim oName As String
            ' The occurrence is returned as a ComponentOccurrence if it's in the
            ' top level of the assembly and as a ComponentOccurrenceProxy if it's in
            ' a sub assembly.  The proxy takes care of any transforms but the work
            ' features aren't available directly from the occurrence so we need to get
            ' them directly from the part and they'll be in part space.  We can then
            ' create a proxy of them to get them in the space of the top level assembly.
            Dim partDef As PartComponentDefinition
            Set partDef = oOcc.Definition
            Dim originWP As WorkPoint
            Set originWP = partDef.WorkPoints.Item(1)
            Dim originWPProxy As WorkPointProxy
            Call oOcc.CreateGeometryProxy(originWP, originWPProxy)
            Debug.Print oName & ": " & originWPProxy.Point.x & ", " & originWPProxy.Point.x & ", " & originWPProxy.Point.Z
    Next
End Sub
Brian Ekins
Mod the Machine blog
Ekinsb,
That code works great!
Thanks a lot!
