Inventor VBA oDoc.Save Does not work
isocam
isocam
Can anybody help?
Can somebody try the following VBA code, using Inventor, to see if the document actually saves?
Public Function SaveDocument()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    oDoc.Save
End Function
Please try  it on "iam", "ipt" & "Idw".
I am running the macro, but, if you look at the file (date & time) properties using "File Explorer" you should (hopefully) see the time & date change. It does not seem to actually save the document when I try!
Is anybody getting the same result???
Many thanks in advance!
Darren
HideoYamada
The document will be saved only when the Dirty property is true.
So you want to overwrite the file even if the document is not dirty,
should set the Dirty property true.
    ' Make oDoc dirty.
    oDoc.Dirty = True
    oDoc.Save
End Function
Best Regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
