Inventor VBA accessing factory table via excel late binding
marcus_scheinberger
marcus_scheinberger
Hello together,
i tried to access a ipart factory table via vba with excel late binding.
I have to use late binding, because we have different versions of excel running in our company and an early binding will lead into problems.
My code works well in case a excel task (in taskmanager) is already running.
When i run my code without an running excel task a new task is created but i cannot access the spreadsheet because it is write protected.
Here is my code and i would appreciate to get an idea how i can solve this problem.
Private Sub AccessFactoryTable()
    Debug.Print ""
    Debug.Print "________________________________"
    Debug.Print ""
    Debug.Print "    Creating factory table"
    Debug.Print ""
    Dim oDoc As Object
    Set oDoc = ThisApplication.ActiveDocument
    ' detecting %TEMP%-Dir...
    Dim TempDir As String
    If Len(Environ$("tmp")) <> 0 Then
        TempDir = Environ$("tmp") & "\"
        Else
            If Len(Environ$("temp")) <> 0 Then
                TempDir = Environ$("temp") & "\"
                Else
                MsgBox "The %TEMP%-Dir could not be detected!", vbCritical + vbOKOnly
    'Debug.Print "TempDir: "; TempDir
    Err.Clear
    Set iPartFactory = oDoc.ComponentDefinition.iPartFactory
    If Err > 0 Or iPartFactory Is Nothing Then
        If MsgBox("Would you like to cerate an iPart?", vbQuestion + vbYesNo, "AccessFactoryTable") = vbNo Then
            End
        Else
            Set iPartFactory = oDoc.ComponentDefinition.CreateFactory
    ' Test if ExcelObject is available, if not create one...
    On Error Resume Next
    'Dim xlWorkbook As Object
    Err.Clear
    Set xlWorkbook = GetObject(, "Excel.Application")
    If Err.Number <> 0 Then
        Debug.Print "Excel is not running! - starting Excel..."
        Err.Clear
        Set xlWorkbook = CreateObject("Excel.Application")
             Err.Clear
             MsgBox ("Could not open Excel!")
             Exit Sub
    xlWorkbook.Visible = True
    'xlWorkbook.Visible = False
    xlWorkbook.Application.DisplayAlerts = False
    Dim xlFile As String
    ' Excel factory table
    xlFile = TempDir & Mid(iPartFactory.ExcelWorksheet.Names.Application.Caption, 19, 33)
    Debug.Print "xlFile: "; xlFile
    'Set iPartFactory = Nothing
     xlWorkbook.Workbooks.Open FileName:=xlFile
     'Set xlWorkbook = iPartFactory.ExcelWorksheet
    Dim oCellRng As Object
    Set oCellRng = xlWorkbook.Cells
    Dim oColumnRng As Object
    Set oColumnRng = xlWorkbook.Columns
    Debug.Print "Creating column: Test"
    oColumnRng(3).EntireColumn.Insert ' Insert a new column to avoid that existing cells get deleted
    oCellRng.Item(1, 3) = "Test"
    oCellRng.Item(2, 3) = "0"
    xlWorkbook.Save
    xlWorkbook.Close (True)
    xlWorkbook.Quit
    Set xlWorkbook = Nothing
    oDoc.Update
End Sub
Vladimir.Ananyev
I have changed your code a little to make more clear different Excel objects – Excel.Application, Workbook, Worksheet, Range.
This works on my side as expected both when Excel is running and when this code has to start new Excel session.
Private Sub AccessExcelApp()
    Err.Clear
    Dim xlApp As Excel.Application
    Set xlApp = GetObject(, "Excel.Application")
        Err.Clear
        Set xlApp = CreateObject("Excel.Application")
             Err.Clear
             Exit Sub
    xlApp.Visible = True
    xlApp.Application.DisplayAlerts = False
    'define some filename
    xlFile = "C:\temp\DATA.xlsx"
    'open workbook
    Dim xlWorkbook As Excel.Workbook
    Set xlWorkbook = xlApp.Workbooks.Open(xlFile)
    'get the reference to the active worksheet
    Dim xlSheet As Excel.WorkSheet
    Set xlSheet = xlWorkbook.ActiveSheet
    'get the reference to the worksheet cell specified by row and column numbers
    Dim oCellRng As Excel.Range
    Set oCellRng = xlSheet.Cells(3, 2)
    'print the cell value
    Debug.Print oCellRng.value
    oCellRng.value = xlApp.WorksheetFunction.PI()
    Stop   '  <-- for debug purpose only
'    xlWorkbook.Save
    xlWorkbook.Close (False)
    xlApp.Quit
    Set xlApp = Nothing
End Sub
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
