Inventor Vb.Net "AddIn" - Syntax Error
isocam
isocam
Can anybody help?
I have the following code that is part of a larger Vb.Net "Addin".
Sub SetPartMaterialProperty(PartMaterial)
       Dim oMaterial As Material
       oMaterial = m_inventorApplication.Activedocument.PropertySets.Item(PartMaterial)
       m_inventorApplication.Activedocument.ComponentDefinition.Material = oMaterial
End Sub
I am trying to automatically set the material of an Inventor part, by specifying the part material, but I cannot get it to work.
(For example, set the part material to "Brass, Soft Yellow")
Can anybody update the above sub-routine for me so that it works correctly?
Many thanks in advance!
Darren
lmc.engineering
Hi @isocam
you can make use of the Materal.Name property here, as below:
Sub SetPartMaterialProperty(PartMaterial As String)
	Dim activeDoc As Document = m_inventorApplication.ActiveDocument
	If TypeOf activeDoc Is PartDocument Then
		Dim Doc As PartDocument = CType(activeDoc, PartDocument)
		Dim def As PartComponentDefinition = Doc.ComponentDefinition
		Try
			def.Material.Name = PartMaterial
		Catch ex As Exception
			Console.WriteLine("Cannot find the material '" & PartMaterial & "'")
		End Try
	Else
		Console.WriteLine("Active document is not a part")
		Return
End Sub
lmc.engineering
I should also add, you can also do it like this, which ensures the appearance updates to the default for that material:
Swap this;
with;
def.Material = Doc.Materials.Item(PartMaterial)
