Inventor vb.net Documents.Open to open assembly with specific View Representation
J_Dumont
J_Dumont
I have a vb.net program that opens a specific file using the below code.
            g_inventorApplication.Documents.Open(tbNewProjectFolderName.Text + "\" + "iBar Grille.iam", True)
Unfortunately, the file opens with the "Primary" View Representation even though the file was saved with another.
nstevelmans
Hi, you can run  this after opening the assembly
Private Sub SetDesignView(Name As String) 'designview name
Dim oAssyDoc As AssemblyDocument = _inventorApplication.ActiveEditDocument
Try
Dim oAssyCompDef As AssemblyComponentDefinition = oAssyDoc.ComponentDefinition
Dim oRepresman As RepresentationsManager = oAssyCompDef.RepresentationsManager
Dim oDesignview As DesignViewRepresentation = oRepresman.DesignViewRepresentations.Item(Name)
If oDesignview IsNot Nothing Then
oDesignview.Activate()
Catch ex As Exception
End Try
End Sub
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
J_Dumont
Thank you so much.
Shortly after submitting my post, I thought the same thing, but your code saved me so much time.
