Inventor VB Duplicate Option Explicit
Nsteel
Nsteel
I'm in the process of creating a VB form for an inventor assembly.
The problem I am having is that when I open the file inventor is duplicating the line "option Explicit" to the ThisDocument code, so when it is opened it all fails. inventor is doing this whether I run the form or not, If I delete both it will add one instance in, which is fine and everything will still work, but if I close and re-open the document a second time I get the same error because it as added a second.
Can anyone offer some advice on this as I'm loosing it with inventor trying to fix it myself,
Ta,
rossano_praderi
Hi, within your VBA editor you have to deselect the option "Require Variable Declaration".
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
