Inventor update "Vault Check-In" button
Wojciech.Lebkowski
Message 1 of 1
Wojciech.Lebkowski
I'm trying to make iLogic that will update the Vault check-in button, if the part is checked-out by me. I have the part that checks status of the file, I'm struggling with the other part, that will update the button.
'API for Vault connection
AddReference "Autodesk.Connectivity.WebServices.dll"
Imports AWS = Autodesk.Connectivity.WebServices
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
Imports VDF = Autodesk.DataManagement.Client.Framework
AddReference "Connectivity.Application.VaultBase.dll"
Imports VB = Connectivity.Application.VaultBase
	Dim mVltCon As VDF.Vault.Currency.Connections.Connection
	mVltCon = VB.ConnectionManager.Instance.Connection
	If  mVltCon Is Nothing Then
		MessageBox.Show("Not Logged In to Vault")
		Exit Sub
	Dim VaultPath As String = ThisDoc.Document.FullFileName
	'Dim VaultPath As String = ThisDoc.PathAndFileName(True)
	VaultPath = VaultPath.Replace("Workspace", "$")
	'flip the slashes
	VaultPath = VaultPath.Replace("\", "/")
	Dim VaultPaths() As String = New String() {VaultPath}
	Dim wsFiels() As AWS.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
	Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(conn,wsFiels(0))
	MsgBox(mFileIt.IsCheckedOutToCurrentUser)
Replies (0)
