Inventor Translator Class ID String
ccoomes
ccoomes
I have created an iLogic rule that outputs the Translator name and Class ID String to a text file if anyone is interested.
Please excuse the code, as I suspect there are better ways or doing it, but it works for me...
Sub Main
	Dim oTextFileName As String = "C:\Temp\Translator AddIn CLSID List.txt"
	Dim oAddIns As ApplicationAddIns
	oAddIns = ThisApplication.ApplicationAddIns
	Dim oTransAddIn As TranslatorAddIn
	WritetoFile(oTextFileName, "Autodesk Inventor Translator AddIns Class ID String", False)
	Dim i As Integer = 1
	For i = 1 To oAddIns.Count
		Try
			oTransAddIn = oAddIns.Item(i)
			WritetoFile(oTextFileName, oTransAddIn.DisplayName & " - " & oTransAddIn.ClassIdString, True)
		Catch
		End Try
	Next
End Sub
Private Sub WritetoFile(TxtFileName As String, TextToAdd As String, Optional ByVal AppendToFile As Boolean = True)
	'Dim dateString = DateTime.Now.ToString("yyyy_MM_dd_HH_mm_ss")
	'Dim TxtFileName As String = ThisDoc.PathAndFileName(False) & "_" & dateString & ".txt"
	If AppendToFile = True Then
		'____Open and append to an existing text file_______
		Dim oAppend As System.IO.StreamWriter
		'oFile = TxtFileName
		oAppend = IO.File.AppendText(TxtFileName)
		oAppend.WriteLine(TextToAdd)
		oAppend.Flush()
		oAppend.Close()
	Else
		'____Create and write to a text file_________________
		oWrite = System.IO.File.CreateText(TxtFileName)
		oWrite.WriteLine(TextToAdd)
		'oWrite.WriteLine("File Created on " & DateString)
		oWrite.WriteLine("")
		oWrite.Close()
End Sub
JelteDeJong
 That sounds like a challenge. What do you think of this?
Dim file As New System.IO.FileInfo("C:\Temp\Translator AddIn CLSID List.txt")
If file.Exists Then file.Delete()
Using writer = file.AppendText()
    writer.WriteLine("Autodesk Inventor Translator AddIns Class ID String")
    For Each addin As ApplicationAddIn In ThisApplication.ApplicationAddIns
        writer.WriteLine(addin.DisplayName & " - " & addin.ClassIdString)
    Next
End Using
Jelte de Jong
Blog: hjalte.nl - github.com
ccoomes
@JelteDeJong thank you for the much simpler code than mine. I knew that there would be a much simpler and neater solution, but mine worked for me at the time.
Thank you for the code, I will update mine now.
