Inventor Studio VBA: Set render iterations or time from code.
Are the number of render iterations or the render time available to be changed while rendering from VBA? I've looked in a lot of places that seemed promising, but so far I've come up short. Below is the GUI access to the options I'm thinking of:
Thanks for your help.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Unfortunately, Inventor studio API does not have a property or method to mention iterations of rendering image. Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thank you for clarifying and for pointing me to the wish list, I will add the suggestion there. I have managed to find a workaround for this issue though: Inventor Studio will save what the last used settings were in terms of the iterations.
In my case, this means that I've saved a blank assembly file as a template set to 100 rendering iterations. All I have to do is open it and create my assembly inside of it, run the renderer from code, and everything works as desired. A little round-about maybe, but it gets the job done.
_KarlH
I too was needing this problem addressed recently. Running batch renders via iLogic driving Inventor Studio only work if the Render Setting is configured to Iterations. Using "Render Time" works once, and then all subsequent renders come out instantly blank.
Hopefully Autodesk can show some love to the Inventor Studio API/iLogic.
