Inventor select face to add constraint
FINET_Laurent
Advisor Advisor
FINET_Laurent
Hi everyone,
I was hoping this whould be an easy task but here is the issue :
From an assembly, I want to add a constraint using the pick command like so :
Dim oFace As Face = ThisApplication.CommandManager.Pick(kPartFaceFilter, "hey")
Constraints.AddMate("Mate1","Door plate 2:2","Face1",Nothing,oFace)
Turns out it doesn't work, and I can't seem to find the way from oFace to the actual part face..
I have found a work around, but I'm still wondering :
Is it even possible ?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
FINET_Laurent
Never mind, found the solution using this command instead :
Dim oFace1 As Face = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Pick Face 1")
Dim oFace2 As Face = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Pick Face 2")
Dim oMateConst As MateConstraint = oAssCompDef.Constraints.AddMateConstraint(oFace1,oFace2,0)
 Still interester in your opinion,
FINET L.
