Inventor rebuild statistics Ilogic rule
Mydus
Message 1 of 1
Mydus
My coworkers and I needed a way to track what was bogging down our machines in large inventor assemblies. Below is an Ilogic rule that will rebuild all parts in an assembly and track the time it takes to rebuild, it will then plot that information into a new Excel workbook. It's not super accurate and will be affected by background processes and such however it has helped us out a lot. It will rebuild all parts multiple times depending  on how many iterations you tell it to run when prompted, it also has a progress bar and inserts in some averages at the end just for fun and ease of use.
'intent: when run program will open excel and plot the times it takes to rebuild each part within the opened assembly
'use case: this program will help show which parts or subassies are most intensive on your machine
'note: these numbers are not 100% accurate and should be taken with a grain of salt, the numbers will be skewed due to background processes
Sub Main()
	iterations = InputBox("How many iterations would you like to run?", "Iterations", "3")'gets the number of runs from user
	iterations = CDblAny(iterations)
	If iterations = vbFalse Then GoTo EndOfFunction 'if you click cancel it quits the program
	If checkErrors() Then
		'this checks the design doctor for errors, if found it asks to continue with the program
		errorContinue = MessageBox.Show("It seems that your assembly has some unresolved errors. WARNING continuing with the program can cause more problems, do you wish to continue?", "Rebuild stats Error checker", MessageBoxButtons.YesNo)
		If errorContinue = vbNo Then GoTo EndOfFunction
	Else
		'MessageBox.Show("no errors found", "Rebuild stats error checker")
	'inventor setup
	Dim Oapp = ThisApplication 'inventor app
	Dim Oassy = Oapp.ActiveDocument 'current assembly
	Dim numParts = Oassy.AllReferencedDocuments.Count'gets total amount of parts in the assembly
	Dim outputString(numParts) As String
	'excel setup
    ExcelSheet = OpenExcel()'sets the variable holding the sheet used for data insertion
	ExcelSheet.cells(2, 1) = "Part Name"
	ExcelSheet.columns("A").columnwidth= 22
	'loop variable setup
	Dim partCounter As Integer'keeps track of part inside of eack run, resets on every run
	Dim progressCounter As Integer'keeps track of parts in total out of all runs(if there are ten parts @ 5 runs this will increment to 50[needed for progress bar])
	progressCounter = 0
	Dim TtlStartTime = Now 'sets the overall time start point(not used)
	For runCounter= 0 To CDblAny(iterations)-1'loops for how many runs/iterations user specified
		partCounter = 0
		For Each Opart As Inventor.Document In Oassy.AllReferencedDocuments'loops through each part in the assembly and rebuilds it
			On Error Resume Next'keeps inventor from crashing if the above loop references a non rebuilable entity
			Dim RebuildStartTime = Now 'sets the start point for the rebuild
			Opart.Rebuild()'rebuilds currently referenced part
			Dim RebuildTime As TimeSpan = Now - RebuildStartTime'the time it took for the current part to rebuild
			'this if statement checks if this is the first run or not(to add in the part names into column a)
			If runCounter= 0 Then
				ExcelSheet.cells(partCounter + 3, runcounter+1) = Opart.DisplayName'adds partname to column a
				ExcelSheet.cells(partCounter + 3, runCounter+ 2) = RebuildTime.TotalSeconds'adds rebuild time to column b
				updateProgress(progressCounter,runcounter,numParts*iterations,iterations,vbFalse,ExcelSheet,TtlStartTime) 'invokes the updateprogress function which updates the progressbar in cell 1
				'^^^^ set argument 5 to vbtrue to skip the progress bar function for very large builds ^^^^^^
				'heading setup for each run
				If partCounter  = 0 Then
					ExcelSheet.cells(2, 2) = "Run 1"
			Else
					ExcelSheet.cells(2, runCounter+ 2) = "Run " & runCounter+ 1
				'next two lines will add the rebuild times for the second and so on runs along with updating the progressbar
			'loop variable increment
			partCounter = partCounter + 1
			progressCounter = progressCounter + 1
		Next
	Next
	runTotals(iterations,partCounter,excelsheet)'adds totals to bottom
	runAverages(iterations, partCounter, excelsheet,numparts)'adds averages to right
	excelsheet.cells(1, 1).value = 1
	excelsheet.range("e1:f1").value = ""
	iLogicVb.UpdateWhenDone = True'updates all parts in assy due to rebuilds(no changes took place this is just cosmetic for the most part)
	Dim EndTrap As Boolean
	If EndTrap = vbTrue Then
		EndOfFunction :'this allows a goto function to end the code instantly
		MessageBox.Show("Canceled", "Rebuild Statistics")
	End Sub
Function runAverages(iterations As Integer,partCounter As Integer, excelsheet As Object,numparts As Integer)
	'adds the averages times to the final column, just inserts excel formula to make it do all the thinking
	excelsheet.cells(2, CDblAny(iterations)+ 2) = "Average"
	For avgloop = 3 To partCounter + 2
		totalRuns = CDblAny(iterations)
		excelsheet.cells(avgloop, totalRuns + 2) = "=average(b" & avgloop & ":" & Chr(totalRuns + 65) & avgloop & ")"
	Next
	'sets the conditional formatting for the color scale on the averages
	cs = excelsheet.range(excelsheet.cells(3,iterations+2),excelsheet.cells(numParts+2,iterations+2))
	With cs.FormatConditions.AddColorScale(ColorScaleType :=3)
		'the lower number colour is GREEN
		With .ColorScaleCriteria(1)
	        .FormatColor.Color = RGB(0, 255, 0)
	        '.Type = xlConditionValueNumber
	    End With
	    'the middle colour is YELLOW
	    With .ColorScaleCriteria(2)
	        .FormatColor.Color = RGB(255, 255, 0)
	    End With
		'the high number colour is RED
	    With .ColorScaleCriteria(3)
	        .FormatColor.Color = RGB(255, 0, 0)
	        '.Type = xlConditionValueLowestValue
	    End With
	End With
End Function
Function runTotals(iterations As Integer,partCounter As Integer, excelsheet As Object)
	'sets the totals at the bottom of the sheet, just inserts excel formula to make it do all the thinking
	excelsheet.cells(partCounter + 4, 1).value = "Total"
	For runCounter= 1 To CDblAny(iterations)
		excelsheet.cells(partCounter + 4, runCounter + 1) = "=sum(" & Chr(runCounter + 65) & 1 & ":" & Chr(runCounter + 65) & partCounter + 1 & ")"
		excelsheet.cells(partCounter + 4, runCounter+ 1).clearformats
	Next
End Function
Function updateProgress(currentpart As Integer,currentrun As Integer,totalparts As Integer, numberOfRuns As Integer,lite As Boolean,excelsheet As Object,TtlStartTime As date)
	'updates the progress bar at the top with the number and the color for the databar
	If Not lite Then
		'the next two lines interpolates the total progress of how many parts have been calculated to 100
		progress = lerp(currentpart, 0, totalparts, 0, 100)
		cfrange = excelsheet.range("A1:D1")
		cfrange.value = progress / 100
		'this small if statement below adds the estimated amount of time left for the calculations to run
		If totalparts > 10 And currentpart > 5 Then 'the first number is how many total parts are needed to add the est time function, the second number is which part to start with
			excelsheet.range("e1").value = "est. time"
			Dim current As TimeSpan = Now - TtlStartTime
			excelsheet.range("f1").value = Round((current.TotalSeconds/currentpart)*(totalparts - currentpart),2) &"s"
		If currentrun = 0 Then
			excelsheet.range("A1:D1").merge'merges the top 5 cells, just to make the progress bar big and easy to read
			'this next chunk just adds the conditional format to show the progress bar
		'End If
			'cfrange = excelsheet.range("A1:D1")
			cfrange.numberformat = "0.00%"
			cfrange.FormatConditions.AddDatabar
			With cfrange.FormatConditions(1)
				.MinPoint.Modify( newtype:=xlConditionValuePercent, newvalue:=0)
				.MaxPoint.Modify( newtype:=xlConditionValuePercent, newvalue:=1)
			End With
		With cfrange.FormatConditions(1).BarColor
			.Color = RGB(255-lerp(progress,0,100,0,255),lerp(progress,0,100,0,255),0)
			.TintAndShade = 0
		End With
		cfrange.FormatConditions(1).BarFillType = xlDataBarFillSolid
		cfrange.FormatConditions(1).Direction = xlContext
		cfrange.FormatConditions(1).NegativeBarFormat.ColorType = xlDataBarColor
		cfrange.FormatConditions(1).BarBorder.Type = xlDataBarBorderNone
		With cfrange.FormatConditions(1).NegativeBarFormat.Color
			.Color = 255
			.TintAndShade = 0
		End With
End Function
Function lerp(input As Integer, x0 As Integer, x1 As Integer, y0 As Integer, y1 As Integer)
	'linear interpolation function
	retval = y0 + (input - x0) * (y1 - y0) / (x1 - x0)
	lerp = retval
End Function
Function OpenExcel()
	myXLS_File = ThisDoc.PathAndFileName(False) & ".xlsx"
	'define Excel Application object
	excelApp = CreateObject("Excel.Application")
	'set Excel to run visibly, change to false if you want to run it invisibly
	excelApp.Visible = True
	'suppress prompts (such as the compatibility checker)
	excelApp.DisplayAlerts = False
	'check for existing file
'    If Dir(myXLS_File) <> "" Then
'    'workbook exists, open it
'    excelWorkbook = excelApp.Workbooks.Open(myXLS_File)
'    ExcelSheet = excelWorkbook.Worksheets(1)
    'Else
    'workbook does NOT exist, so create a new one
    excelWorkbook = excelApp.Workbooks.Add
	openexcel = excelWorkbook.Worksheets(1)
	Return excelWorkbook.Worksheets(1)
End Function
 Function checkErrors() As Boolean
	'checks the error manager for any active errors in the current application
    Dim errorMng As ErrorManager
    errorMng = ThisApplication.ErrorManager
    Dim errors As String
    errors = errorMng.AllMessages
	If errors <>"<ErrorsAndWarnings/>" or ThisApplication.UserInterfaceManager.Ribbons.Item("Drawing").QuickAccessControls.Item("AppDesignDoctorCmd").ControlDefinition.Enabled = True Then
		checkerrors = vbTrue
	else
		checkErrors  = vbFalse
	'https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/vba-check-design-doctor-for-errors-in-drawing/td-p/3809941
	'https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/bug-with-checking-errormanager-with-vba/m-p/4932720
end function
Replies (0)
