Inventor iLogic - Get the Loop lengt for flat pattern
ryabinina_olya
ryabinina_olya
Hi all!
I want to get Loop lenght from Mesuare tool for top face in flat pattern.
I have found a method for MeasureTools.GetLoopLength in the VBA object browser, but I can use it for sketch only(((
I have tried to create sketch for top face, but I don't now what I need to do next for getting Loop lenght.
Can someone help me with this?
Thank you in advance!!
Olga Ryabinina
Professor Assistant in Voronezh State Technical University
Sergio.D.Suárez
Try the following ilogic rule.
Dim oFace As Face = ThisApplication.CommandManager.Pick(15877, "Select Face")
Dim oLength As Double = 0
Dim minParam As Double, maxParam As Double, curveLength As Double
For Each oEdge As Object In oFace.Edges
	oEdge.Evaluator.GetParamExtents(minParam, maxParam)
	oEdge.Evaluator.GetLengthAtParam(minParam, maxParam, curveLength)
	oLength = oLength + curveLength
Next
MessageBox.Show(Round(oLength,3) & " cm")
I hope this helps with your work. Cheers
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
ryabinina_olya
Thank you very much!!! It really works!!
Olga Ryabinina
johnsonshiue
Hi! Do you have to have the exact length of the external loop? Or, the flat pattern extent area would be sufficient? The extent area can be obtained easily using iLogic rule or custom iProperty.
Many thanks!
Software Test Engineer
ryabinina_olya
Hello!
I have a problem with this rule.
I changed it for automatic top face specifying in flat pattern and when I use Emboss Feature it makes another result now.
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
If oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    Dim oDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
    If Not oDef.HasFlatPattern Then
        oDef.Unfold()
    Dim oFlatPattern As FlatPattern = oDef.FlatPattern
	Dim oFace As Face = oFlatPattern.TopFace
	oLength = oLength + curveLength 'cm
Next
 On first screen - correct result with your rule, on second screen - wrong result with my rule
I can't understand. Can you help me?
Olga Ryabinina
ryabinina_olya
Hello!
I need exact summary lenght of all edges on top face including internal pockets, edges of engraving etc.
Olga Ryabinina
