Inventor iLogic Function To Pull Data From An Access Database
Split from solved post how can i get iproperty values filled in by reading an excel file to new thread for clarity.
Is there an iLogic function, similar to the above code, that can pull data from an Access database?
GoAccess.DisplayAlerts = False
DESC = GoAccess.CellValue("//myDrive/Projects/iTEST.xlsx", "DATA", "A2")
iProperties.Value("Project", "Description") = DESC
InventorVb.DocumentUpdate()
GoAccess.Close
Obviously there would be additional formatting to dig to the cell you want in a table etc... but can it be done?
Also - is there a reverse process to this such that additional data that was typed in an iPart field could then be pushed back into the database (or Excel)?
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that article in below blog link may be helpful.
https://adndevblog.typepad.com/manufacturing/2017/08/connecting-microsoft-access-via-inventor-ilogic.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
