Inventor iLogic - Fix of Break and Ballon Commands
berat_kandira
berat_kandira
I want to use "break" command and "ballon" with iLogic on Inventor Drawing.
1) When I use "break" command , viewed total length is changing after I changed length parameter. I want that breaked total length dont change any time. Because total length overflow of drawing paper, I dont want that.
2) When I use "ballon" command manually in drawing and after parameters chaged, all ballons mix together. I want that dont change.
How can I solve this problems ?
A.Acheson
Hi @berat_kandira
From what your describing the geometry in the view is moving due to the break but the balloons are not. I don't believe there is any good solution to this problem short of rearranging all the balloons to be a certain distance from the attachment points. Can you please attach an image of the issue, the code your using and what you expect the outcome to be?
Regards
Alan
