Inventor ILogic Book request
roy7BB24
roy7BB24
Hi All
I'm a reasonably experienced inventor user, but haven't really used ILogic at all, I was wondering if anyone had any recommendations for a book on the topic to get me started, or any tutorials that will get me started.
My first project I'm looking at will probably be a little macro to rename all the parts in an assembly as well as some other processing to improve the way I'm doing BOM's and file management if that helps at all
(Had a quick look on amazon but nothing there really stood out)
Kind Regards
Roydon Mackay
tyler.warner
Ascent publishes training manuals for Autodesk. Their material is pretty good for getting started on a topic.
Ascent - Inventor iLogic
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Edward_Lowe
I learned about iLogic via online sources, primarily youtube.  If you open youtube and enter 'Autodesk Inventor ilogic' you will find a comprehensive series of tutorials broken into 69 clips ranging from approx 2 minutes to 10 minutes each.  Use this to get you up and running.  For more difficult coding your best bet is to place a post on here.  I have always found this forum membership massively supportive, even with the most obscure and difficult requests.  Good luck!!
Edward
WCrihfield
Just dropping another link in here...which is mostly a link to other useful links I have come across, and believe to be helpful in learning about iLogic.
Learning about Inventor's iLogic
Wesley Crihfield
(Not an Autodesk Employee)
