Inventor I logic bombs at second sheet of BOM
t_fransman
t_fransman
I have an ilogic written before my time that has stopped working. It seems to end if there are sheets that don't have a PL on them. I need to retain all attributes for the first couple sheets. Then renumber the sheets so it displays the sheet that the pl came from correctly. Please don't change the first two sheets they work as intended. Here is the code. It used to work fine before install of 2021 Inventor and maybe new excel version or update. I need it to cont. if a sheet has no bom, and renumber sheet name on tabs. Ignore the first two sheets, that just  puts it in our BOM system and adds routings. Just need to fix the thing so it gets all of the sheets again from the idw that have a BOM and renumbers accordingly. Any help greatly appreciated.
Dim oDoc As Document = ThisDoc.Document
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSheets As Inventor.Sheets = oDrawDoc.Sheets
Dim oSheet As Sheet
Dim oRevTable As RevisionTable = oSheets(1).RevisionTables.Item(1)
RevLevel = oRevTable.RevisionTableRows.Count
'get the path and name of the drawing file
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
FullName = path_and_name & ".xls"
'check for existing XLS file and delete it if found
ExistingFile = Dir(path_and_name & ".xls*")
If ExistingFile <> "" Then
	i = MessageBox.Show("The file already exists: " & vbCr & vbCr & path_and_name & ".xls" & vbCr & vbCr & "Do you want to overwrite the file?", "File Exists", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
	If i = vbYes Then
		Kill (FullName)
	Else
		Exit Sub
Else
iCount = 1
For SheetNum = oSheets.Count To 1 Step -1
	ThisApplication.StatusBarText = "Exporting Sheet " & iCount & " of " & oSheets.Count & "    Please Wait!"
	Try
		oPartslist = oSheets(SheetNum).PartsLists(1)
		' create a new NameValueMap object
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		'specify an existing template file
		'to use For formatting colors, fonts, etc
		'oOptions.Value("Template") = ThisDoc.Path & "\BOM Template.xlsx"
		'specify the columns to export
		'oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION"
		'specify the start cell
		oOptions.Value("StartingCell") = "A2"
		'specify the XLS tab name
		'here the file name is used
		oOptions.Value("TableName") = "BOM-Sheet " & SheetNum 'without extension
		'choose to include the parts list title row
		'in this example "Ye Old List of Parts" is written to the StartingCell
		oOptions.Value("IncludeTitle") = False
		'choose to autofit the column width in the xls file
		oOptions.Value("AutoFitColumnWidth") = True
		' export the Partslist to Excel with options
		oPartslist.Export(FullName, PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
	Catch
	End Try
	iCount = iCount + 1
	LastSheet = SheetNum
Next
ThisApplication.StatusBarText = "Finalizing BOM Export     Please Wait!"
xlLeft = -4131
xlCenter = -4108
xlRight = -4152
xlContinuous = 1
xlEdgeLeft = 7
xlEdgeTop = 8
xlEdgeBottom = 9
xlEdgeRight = 10
xlInsideVertical = 11
xlInsideHorizontal = 12
ExcelApp = CreateObject("Excel.Application")
ExcelApp.Visible = False
ExcelApp.DisplayAlerts = False
ExcelWorkbook = ExcelApp.Workbooks.Open(FullName)
'''Format Export
Dim SheetCount As Integer
Dim Fail as Boolean
Dim DropCount As Integer
SheetCount = 1
For Each sh In ExcelWorkbook.Worksheets
		sh.Range("A:G").HorizontalAlignment = xlLeft
		With sh.Range("A1:G1")
			.Value = "COMPONENT COMBINED BILL OF MATERIALS"
			.MergeCells = True
			.Font.Size = 18
			.Font.Bold = True
			.HorizontalAlignment = xlCenter
		End With
		With sh.Range("A2:G2")
			.Font.Bold = True
			.Borders(xlEdgeLeft).LineStyle = xlContinuous
			.Borders(xlEdgeTop).LineStyle = xlContinuous
			.Borders(xlEdgeBottom).LineStyle = xlContinuous
			.Borders(xlEdgeRight).LineStyle = xlContinuous
			.Borders(xlInsideVertical).LineStyle = xlContinuous
		End With
		sh.Columns("A").ColumnWidth = 8.5
		sh.Columns("B").ColumnWidth = 8.5
		sh.Columns("C").ColumnWidth = 122.5
		sh.Columns("D").ColumnWidth = 39
		sh.Columns("E").ColumnWidth = 35
		sh.Columns("F").ColumnWidth = 8
		sh.Columns("G").ColumnWidth = 24.5
		With sh.PageSetup
			.Zoom = False
			.FitToPagesWide = 1
			.FitToPagesTall = False
			.Orientation = 2
		End With
Next
'''Routings
RoutingSheet = ExcelWorkbook.sheets.Add
RoutingSheet.Name = "Routings"
RoutingSheet.Columns("A").ColumnWidth = 17
RoutingSheet.Columns("B").ColumnWidth = 11
With RoutingSheet.Range("A1:B1")
	.MergeCells = True
	.Value = "Shop Routings"
	.Font.Size = 18
	.Font.Bold = True
End With
RoutingSheet.Range("B:B").HorizontalAlignment = xlCenter
With RoutingSheet.Range("A1:B16")
	.Borders(xlInsideHorizontal).LineStyle = xlContinuous
End With
With RoutingSheet.PageSetup
	.Zoom = False
	.FitToPagesWide = 1
	.Orientation = 1
End With
RoutingSheet.Range("A2:B2").Font.Bold = True
RoutingSheet.Range("A2").Value = "WORK CENTER"
RoutingSheet.Range("B2").Value = "HOURS"
RoutingSheet.Range("A3").Value = "PROGRAMING"
RoutingSheet.Range("A4").Value = "BURN/CLEAN"
RoutingSheet.Range("A5").Value = "LAY/FAB"
RoutingSheet.Range("A6").Value = "MACHINING"
RoutingSheet.Range("A7").Value = "WELDING"
RoutingSheet.Range("A8").Value = "ASYTST-M"
RoutingSheet.Range("A9").Value = "CLEAN/PAIN"
RoutingSheet.Range("A10").Value = "ASYTST-E"
RoutingSheet.Range("A11").Value = "STOCKTST"
'''Properties
PropertiesSheet = ExcelWorkbook.Sheets.add
PropertiesSheet.Name = "Component Properties"
PropertiesSheet.Columns("A").ColumnWidth = 14.25
PropertiesSheet.Columns("B").ColumnWidth = 94
With PropertiesSheet.Range("A1:B1")
	.MergeCells = True
	.Value = "Job Specific Data Table & Component Properties"
	.Font.Size = 18
	.Font.Bold = True
End With
PropertiesSheet.Range("A2:A9").Font.Bold = True
PropertiesSheet.Range("A2").Value = "Job#"
PropertiesSheet.Range("B2").Value = iProperties.Value("Custom", "JOB NO")
PropertiesSheet.Range("A3").Value = "Mark#"
PropertiesSheet.Range("B3").Value = iProperties.Value("Custom", "MARK NO")
PropertiesSheet.Range("A4").Value = "Desc."
PropertiesSheet.Range("B4").Value = iProperties.Value("Custom", "SHORT DESC")
PropertiesSheet.Range("A5").Value = "Ext Desc."
PropertiesSheet.Range("B5").Value = iProperties.Value(iProperties.Value("Project", "Part Number")&".iam", "Project", "Description")
PropertiesSheet.Range("A6").Value = "P/N"
PropertiesSheet.Range("B6").Value = iProperties.Value("Project", "Part Number")
PropertiesSheet.Range("A7").Value = "Drawing"
PropertiesSheet.Range("B7").Value = iProperties.Value("Project", "Part Number")
PropertiesSheet.Range("A8").Value = "Revision"
PropertiesSheet.Range("B8").Value = RevLevel
PropertiesSheet.Range("A9").Value = "Make Qty"
PropertiesSheet.Range("B9").Value = iProperties.Value("Custom", "MAKE QTY")
PropertiesSheet.Range("A33").Value = "UserID"
PropertiesSheet.Range("B33").Value = System.Environment.UserName
PropertiesSheet.Range("A34").Value = "MachineID"
PropertiesSheet.Range("B34").Value = System.Environment.MachineName
PropertiesSheet.Range("B:B").HorizontalAlignment = xlLeft
With PropertiesSheet.Range("A1:B9")
End With
With PropertiesSheet.PageSetup
	.Zoom = False
	.FitToPagesWide = 1
	.Orientation = 2
End With
ExcelWorkbook.Save
i = MessageBox.Show("Export completed successfully!" & vbCr & vbCr & "Would you like to view the output now?", "Export Complete", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
If i = vbNo Then
	ExcelWorkbook.Close
	ExcelApp.Quit
Else
	ExcelApp.Visible = True
ExcelWorkbook = Nothing
ExcelApp = Nothing
t_fransman
Dim oSheet As Sheet
	If i = vbYes Then
		Kill (FullName)
	Else
		Exit Sub
Else
iCount = 1
	Try
	Catch
	End Try
	iCount = iCount + 1
Next
xlLeft = -4131
xlCenter = -4108
xlRight = -4152
xlContinuous = 1
xlEdgeLeft = 7
xlEdgeTop = 8
xlEdgeBottom = 9
xlEdgeRight = 10
'''Format Export
Dim Fail as Boolean
SheetCount = 1
			.MergeCells = True
			.Font.Size = 18
			.Font.Bold = True
		End With
			.Font.Bold = True
		End With
		With sh.PageSetup
			.Zoom = False
			.FitToPagesWide = 1
			.Orientation = 2
		End With
Next
'''Routings
	.MergeCells = True
	.Font.Size = 18
	.Font.Bold = True
End With
End With
	.Zoom = False
	.FitToPagesWide = 1
	.Orientation = 1
End With
'''Properties
	.MergeCells = True
	.Font.Size = 18
	.Font.Bold = True
End With
End With
	.Zoom = False
	.FitToPagesWide = 1
	.Orientation = 2
End With
ExcelWorkbook.Save
If i = vbNo Then
	ExcelWorkbook.Close
	ExcelApp.Quit
Else
ExcelApp = Nothing
A.Acheson
Is the code posted as is working to export the partslist? I have looked at the code and this is purely a partslist export to excel. No drawing sheets are renamed. I assume you want to add to its functionality with either a rename or sort of the Drawing sheets?
Is the partslist on it’s own sheet or with a drawing? What do you intend to call the sheet with the partslist? An image of the layout as you would manually do this would be good.
Regards
Alan
t_fransman
It creates a title page that imports into our B.O.M. software as sheet one, a routings page which imports as sheet two ( both work. But it used to get all the B.O.M. sheet and make a tab for each with the proper number for each sheet. Now it stops  if the idw has a sheet that without a B.O.M.on it. I need it to continue and skip the sheets with no B.O.M. and get the rest. It used to say the correct sheet numbers for each sheet with a B.O.M. on it. That went directly into our BOM software, so a note was created saying which idw sheet each B.O.M. was on in our B.O.M. software. Worked perfectly before, still does except to some degree, the only issue is that it stops if there is no B.O.M. on any sheet in idw. No idea why always worked fine until in installed inventor 2021.
t_fransman
 used to create a sheet for each idw page with the proper number on the tab. It says BOM sheet 1 and lets say it skipped a page in the idw because details were on page 2 and 3 then it would resume and correctly name the tab as BOM Sheet 4 or whatever, now it just stops after no BOM is detected on any sheet in the idw. Everything else is working still as intended.
