Inventor First Run
Inventor First Run
msabotto
Inventor First Run
msabotto
Is there a way to understand, from an Addin point of view, that the current account is lunching Inventor for the very first time?
I'm trying to understand if I could connect to this "state" and start a simple Wizard to help the user configuring Inventor.
Any idea please?
thanks
msabotto
really nothing to share on this topic?
thanks
JelteDeJong
The start class of your addin has a method called "Activate" (which implements "ApplicationAddInServer.Activate") That method has a parameter FirstTime. I think you can use that parameter for what you want.
Jelte de Jong
Blog: hjalte.nl - github.com
tobias_wiesendanger
I think that wont help him because this just reports if the addin gets loaded the first time in the running session. This is false after reset ribbon as far as I remember.
But there is something that could help and thats the registry.
This is the startcount. In my case Inventor was started 172 times. Maybe this is 0 when you have a fresh install.
msabotto
Thanks for the suggestion, but as the documentation says, it is TRUE or FALSE depending on your Addin loading process and not Inventor.
If I well remember it could become TRUE again if you change the Addin FileVersion while evolving the addin itself (not completely sure).
Many Thanks
msabotto
Cool suggestion, it is seems to be useful for what I'm trying to realize, many thanks for this tip.
