Inventor Environments Ribbon for Frame analysis
sunarjo
sunarjo
Dear Sir/ Madam,
I already success installed Inventor Profesional 2017 and Nastran In-Cad. but I difficult to find from the Ribbon Menu option Frame Analysis Icon. Only Icon stress Analysis and Icon Autodesk Nastran In-Cad.
May be, Icon Frame Analysis the same with Autodesk Nastran In-Cad Icon ???
I also attached the screenshoot.
Thank you .
Sunarjo Leman
Email: sunarjo@ft.untar.ac.id
Binga
Hello.
Welcome to the Autodesk Community!
You can't find the Frame Analysis within a part file.
Try opening a assembly file.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
sunarjo
Ok. Thank you very much for your support.
I got it.
regards
