Inventor crashs when run automatically
mk92
Message 1 of 1
mk92
Inventor keeps crashing. If i run the first rule without the last line manually and then the second rule manually its no problem. Even if L is changed.
If i try it like this automatically, because of the Parameter L changes to another value,  inventor crashes. Any idea?
First (Test 1) :
d1055 = 1*Ceil(L/2000+1)
d1066 = (L-2*550)/(d1055-1)
d996 = d1055
d998 = d1066
RuleParametersOutput()
InventorVb.DocumentUpdate(False)
iLogicVb.RunRule("Test_2")
Second (Test 2) :
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
Dim oSketches As PlanarSketches
oSketches = ThisApplication.ActiveDocument.ComponentDefinition​.Sketches
Dim oSketch As PlanarSketch
oSketch = oSketches.Item("Skizze128")
' Create a profile.
Dim oProfile As Profile
oProfile = oSketch.Profiles.AddForSolid
Dim MyArrayList As New ArrayList
'look at the workplane collection
For Each oWorkPlane In ThisDoc.Document.ComponentDefinition.WorkPlanes
MyArrayList.add(oWorkPlane.Name)
Next
oWorkPlane1 = MyArrayList.item(40)
Dim oToEntity As Inventor.WorkPlane
If oWorkPlane.Name  = oWorkPlane1 Then
'select the
oToEntity = oWorkPlane
Next
Dim oFeatures As PartFeatures
oFeatures = ThisApplication.ActiveDocument.ComponentDefinition​​.Features
'delete the feature
Try
oFeatures("Extrusion_X").delete
Catch
End Try
' Create an extrusion
Dim oExtrude As ExtrudeFeature
oExtrude = oCompDef.Features.ExtrudeFeatures.AddByToExtent _
(oProfile, oToEntity, kJoinOperation)
oExtrude.Name = "Extrusion_X"
ThisApplication.CommandManager.ControlDefinitions.​​Item("FinishSketch").Execute
InventorVb.DocumentUpdate()
Replies (0)
