Inventor.ButtonDefinition for multiple buttons
w.pepping
w.pepping
I have an add-in that creates multiple buttons (in a separate panel) within the ribbon-tabs.
If I use this, only the last added button can be fired:
 Private WithEvents m_Button As ButtonDefinition
 Private Sub m_Button_OnExecute(Context As NameValueMap) Handles m_Button.OnExecute
        '  action here....
 End Sub
 I have also tried to put all ButtonDefinitions in a list. All buttons can be fired now, but I cannot find out which button is fired.
  Private WithEvents ButtonList As New List(Of ButtonDefinition)
Gives the Inventor API a solution for this, or is there a good workaround?
Get control of your sheet metal files.
Download the app from matprop.com
matt_jlt
Hi, if i am reading your question correctly, what you need to do is create a new button definition for each button. Then add each of those to your button collection. That's my best guess for the limited information you provided.
 Private WithEvents m_Button1 As ButtonDefinition
 Private Sub m_Button1_OnExecute(Context As NameValueMap) Handles m_Button1.OnExecute
        '  action here....
 End Sub
 Private WithEvents m_Button2 As ButtonDefinition
 Private Sub m_Button2_OnExecute(Context As NameValueMap) Handles m_Button2.OnExecute
        '  action here....
 End Sub
Hopefully this helps.
Regards, Matt.
w.pepping
Thank you Matt.
Your solution works if you know which buttons you have. In my case the buttons are read from a configurable XML file. So I don't know how many buttons there will be. To make the code easier, I try to put the ButtonDefinitions in a collection first.
w.pepping
I have found a solution to assign multiple buttons in case the number of buttons and their actions need to be configurable. In my case they are read from an XML file.
For this I have modified the code in this post from Philippe Leefsma.
I removed the 'ReplaceNativeControls'  and added the buttons into a custom panel in the ribbon.
    Private _customButtonDefinition As ButtonDefinition
Public Sub New(objNode As XmlNode, oButtonConfig As String)
   dim m_DynamicRibbon As Ribbon = g_inventorApplication.UserInterfaceManager.Ribbons.Item(DynamicRibbon)
   dim m_DynamicTab As RibbonTab = m_DynamicRibbon.RibbonTabs.Item(DynamicTab)
dim PanelIndex as string = "RibbonUI" & DynamicTab
        Try
           dim m_DynamicPanel As RibbonPanel = m_DynamicTab.RibbonPanels.Item(ControlChars.Quote & PanelIndex & ControlChars.Quote)
        Catch ex As Exception
        End Try
        If m_DynamicPanel Is Nothing Then m_DynamicPanel = m_DynamicTab.RibbonPanels.Add("Cadix", PanelIndex, g_addInClientID)
        m_DynamicPanel.CommandControls.AddButton(_customButtonDefinition, True)
End Sub
