Inventor button not working, button created using C#
madhukum339
madhukum339
I'm using the below C# code to create a custom tab with panel and button in Inventor 2024. but upon clicking the button it's not executing. Please correct the code if needed. Thanks in advance
private void CreateCustomTab(string tabName)
UserInterfaceManager uIManager = m_inventorApplication.UserInterfaceManager;
if (uIManager.InterfaceStyle == InterfaceStyleEnum.kRibbonInterface)
Ribbon ribbon = uIManager.Ribbons["Assembly"];
RibbonTabs rTabs = ribbon.RibbonTabs;
foreach (RibbonTab tab in rTabs)
if (tab.DisplayName.Equals(tabName))
return;
rTabs.Add(tabName, "Test", clsid, "", true, false);
RibbonTab rTab = ribbon.RibbonTabs["Test"];
RibbonPanels panels = rTab.RibbonPanels;
foreach (RibbonPanel panel in panels)
if (panel.DisplayName != null && panel.DisplayName.Equals("WPF Form"))
panel.Delete();
RibbonPanel newPanel = rTab.RibbonPanels.Add("WPF", "InventorAddinServer.RibbonPanel_" + Guid.NewGuid(), clsid, String.Empty, true);
CommandControls cmdCtrls = newPanel.CommandControls;
ButtonDefinition button1 = m_inventorApplication.CommandManager.ControlDefinitions.AddButtonDefinition("OpenWPF", "InventorAddinServer.OpenWPFButton_" + Guid.NewGuid(), CommandTypesEnum.kShapeEditCmdType);
button1.OnExecute += Button1_OnExecute;
cmdCtrls.AddButton(button1);
button1.Enabled = true;
button1.Execute();
private void Button1_OnExecute(NameValueMap Context)
//trying to open a wpf window on button click
MainWindow mainWindow = new MainWindow(m_inventorApplication);
I'm using the class Guid as the clsid to create the tab and button.
jjstr8
You're not showing your window in Button1_OnExecute, just creating the window. Also, delete the "button1.Execute();" line when creating the button, unless you want the window to show when Inventor starts and loads your add-in.
mainWindow.Show(); // or mainWindow.ShowDialog()
