inventor bug ?
inventor bug ?
inventor bug ?
Hi folks
I have some code that puts some values from parameters in an arry and sorts them and then uses the middel 2 values to do some calculations.
Now this code works but i have a problem when i run my form that triggers the rules then ilogic repeats some of the rules multiple times .
i have three rules the 1st en 2nd are correct but the 3th repeats multiple times and i don't know why.
in attachement you can find a screen cast of my problem, my appollogies its in dutch to put my code in english it would take for ever.
Code 1
SyntaxEditor Code Snippet
If Start= True Then
Dim MyArrayList(3) As Double
MyArrayList(0) = X_Afstand_1_Pir
MyArrayList(1) = X_Afstand_2_Pir
MyArrayList(2) = X_Afstand_3_Pir
MyArrayList(3) = X_Afstand_4_Pir
Array.Sort(MyArrayList)
For Each Str As Double In MyArrayList
Next
MessageBox.Show(MyArrayList(1), "Co�rdinaat X1")
MessageBox.Show(MyArrayList(2), "Co�rdinate X2")
I1=Abs(MyArrayList(1))/((Binnen_diameter_Pir/2)+Laagdikte_Pir)
J1=(Asin(I1)*180)/3.1415
M1=Abs(MyArrayList(2))/((Binnen_diameter_Pir/2)+Laagdikte_Pir)
N1=(Asin(M1)*180)/3.1415
'Q1=J1+N1 elseif het gene hieronder ?
If MyArrayList(2)<0 And MyArrayList(1)< 0 Then Q1=J1-N1 Else If MyArrayList(2)>0 And MyArrayList(1)> 0 Then Q1=N1-J1
MessageBox.Show(Q1, "Hoek tussen X1 en X2")
 code 2
If Start= True Then
Next
MessageBox.Show(MyArrayList(1), "Co�rdinaat X3")
MessageBox.Show(MyArrayList(2), "Co�rdinaat X4")
 Q1=J1+N1
 MessageBox.Show(Q1, "Hoek tussen X3 en X4")
 If Start= True Then
MyArrayList(0) = Y_Afstand_1_Pir
MyArrayList(1) = Y_Afstand_2_Pir
MyArrayList(2) = Y_Afstand_3_Pir
MyArrayList(3) = Y_Afstand_4_Pir
Next
MessageBox.Show(MyArrayList(1), "Co�rdinaat Y1")
MessageBox.Show(MyArrayList(2), "Co�rdinaat Y2")
Hoek_Alpha_Pir=(afstand_tussen_de_trekken*360)/(Binnen_diameter_Pir*3.1415)
MessageBox.Show(Abs(Hoek_Alpha_Pir), "hoek booglengte")
Owner2229
Well, to stop the rule from running multiple times you can do this:
If Start = False Then Exit Sub
Parameter("Start") = False
'... rest of the code
'Don't forget to remove the "End If" at the end of your code
'End If
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
how can is use that bit of code so that my other codes still work because now the where i put your solution still works and doesnt repeat anymore but my other codes won't work and thanks for your fast reply
i found a solution for it 😛
Would you know why this happens that code repeats its self? Because i never told it to repeat ?
Owner2229
To make the consequent rules run, you can re-enable the "start" parameter:
'End If
Parameter("Start") = True
I believe it starts again because you're changing the parameter "Hoek_Alpha_Pir" in your 3th rule, which triggers it.
Mike
the plane for Hoek_Alpha_Pir is plane thats under an angle and the plane for hoek tussen X1 en X2 is just one that is parrallel to my origin plane.
why does the plane for hoek tussen X1 en X2 cause no trouble and the plane under angel does cause trouble?
