Inventor Browser Customization
I have been in the field for the last year so I am returning to a few minor customization issues that are small but are driving me mad.
In the standard browser, while modeling, the constraint lines have the file names of each part constrained in parenthesis. How do I turn this off?  The file names are getting longer and longer and I just flat out do not need to see all of that.
EX- Flush:193 (123456.LO2.sub_a:17, 123456.LO2._sub_b_alter:15) (156.000in)
Can I just have this? - Flush:193 (156.000in)
If I need to determine which part is constrained to which I can just look, its really not necessary and I waste time screwing around with this.
Please help me.
stuart_smith82
This is an application option if you go to Tool Tab> options Panel> Application options and disable the following;
You should get constraint name only.
Stuart Smith
Group Data Management Consultant Graitec UK
stuart.smith@graitec.co.uk | www.graitec.co.uk
Blog: https://www.graitec.co.uk/blog/blogger/smith
Graitec Manufacturing Blog: https://www.graitec.co.uk/blog/categories/mechanical
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
