Inventor Apprentice: copy from Custom properties to IV properties
stefaanboel
stefaanboel
Does someone have a tool to copy properties from custom properties to Inventor properties?
Also the possibility to select what custom propertie should be copied to what Inventor propertie.
Since it's a very large amount of files I prefere to have something done with Inventor Apprentice.
tnx in advance!
If this is the solution, push the solution button Smiley Wink (and maybe some kudos)
Vladimir.Ananyev
It is not difficult to develop the custom tool for this job.
You may find several articles published in the DebBlogs.  This one is good to start:
Accessing iProperties
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
You are absolutely right, Apprentice is much more faster than Inventor if you need to change iProperties only.  The following blog post describes the Apprentice functionality useful when you process iProperties:
iProperties Without Inventor (Apprentice)
http://modthemachine.typepad.com/my_weblog/2010/03/iproperties-without-inventor-apprentice.html
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
