INVENTOR API - User Interface Tool
Khoa_NguyenDang
Khoa_NguyenDang
HI all
Does anybody know what the name and keyword for the select pop up when use command in Inventor
And How to create it with API code in Inventor
Thank you so much
WCrihfield
I don't know what the proper keyword if for it, but I know it appears due to a certain setting within Inventor's Application Options > General tab > Selection area.  When you check the box to enable this "Enagle Optimized Selection" option, it causes that little 'mini toolbar' to start appearing when you hover over any select-able objects in the graphics window.  You can specify how long it should wait before showing this tool, and the location tolerance, which specifies how far away your cursor/pointer can be from objects for it to still recognize them and add them to the list of available objects to select.
Below is a screen shot of this setting within the Application Options.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
Wesley Crihfield
(Not an Autodesk Employee)
JelteDeJong
I think you need the RadialMarkingMenu.
Have a look at this post.
https://modthemachine.typepad.com/my_weblog/2012/03/customizing-marking-menus.html
Jelte de Jong
Blog: hjalte.nl - github.com
