Inventor API - The wrong position of bodies when use COPY OBJECT in Inventor
Khoa_NguyenDang
Khoa_NguyenDang
Hi all guys
I am coding a tool to copy the solid bodies form this part to the other part.
But when i start my code, it work. But the problem is the position of the copied solid bodies is not the same with the origin part (As picture i post)
I thicnk may be when i use the copy method code it doesn't know what the assembly i base on to do the copy
Do anybody met this problem before, hope someone can help me.
YuhanZhang
Can you provide your code snippet(and non-confidential data if possible) to reproduce the issue?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
