[Inventor API] Problem with Thicken Command
Khoa_NguyenDang
Message 1 of 11
Khoa_NguyenDang
Hi all
I am facing a problem with Thicken Command
Here is the code I use. It just normal is for each face of Solid [1], I will create the Thicken Feature. But when it run I just can create the thicken for the first Face, for the Second face of solid, it will be an error to access that face for Thicken Feature. So it means the problem is can not define the face after the first Thicken, I also tried to get the InternalName of Face after the first Thicken, the same error show.
SurfaceBody sb = partDef.SurfaceBodies[1];
sb.Name = "Panel";
foreach (Face face in sb. Faces)
FaceCollection FacesCol = default(FaceCollection);
FacesCol = _invApp.TransientObjects.CreateFaceCollection();
ThickenFeature oThickFeat = default(ThickenFeature);
FacesCol.Clear();
FacesCol.Add(face);
try
oThickFeat = partDef.Features.ThickenFeatures.Add(FacesCol, "1", PartFeatureExtentDirectionEnum.kNegativeExtentDirection, PartFeatureOperationEnum.kNewBodyOperation, false);
catch
MessageBox.Show("Error");
The error like the picture I attached
Have anybody met the same problem before, if someone knows it, please help me. Thank you so much.
Replies (10)
Message 2 of 11
Ralf_Krieg
Hello
Why do you create the thicken feature for each face itself? You can add all faces in one FaceCollection and call the thicken feature with this Collection.
In your way, it is possible that the first thicken feature modifies the model so that face2 in the surfacebody.faces collection is not longer existing.
I didn't test it, but you can try loop after each thicken feature for 1 face through the surfacebody.faces collection from start and check for each face if it's createdbefeature.type property is kthickenfeatureobject, else call thickenfeature for this face.
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 3 of 11
dutt.thakar
@Khoa_NguyenDang
Can you upload your part in which you are trying to use the code?
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Message 4 of 11
Khoa_NguyenDang
Just a normal Part Rectangle file @dutt.thakar
Message 5 of 11
Khoa_NguyenDang
HI @Ralf_Krieg
For my code, it will recreate a FaceCol for each Face
I also create a FaceCol before Loop, but the problem still have problem
Message 6 of 11
dutt.thakar
@Khoa_NguyenDang
Can you try the below code and see if that helps? I have just removed the automatic face chains in the code and tested the code on a rectangular box.
sb.Name = "Panel";
FacesCol.Clear();
FacesCol.Add(face);
try
oThickFeat = partDef.Features.ThickenFeatures.Add(FacesCol, "1", PartFeatureExtentDirectionEnum.kNegativeExtentDirection, PartFeatureOperationEnum.kNewBodyOperation);
catch
Dutt Thakar
LinkedIn
Message 7 of 11
Ralf_Krieg
Hello
I think the problem is, that the first thicken feature creates new faces and invalidates the faces collection. You have to collect all the faces you need in a new collection and travers this one. An example in VBA.
Private Sub Thicken()
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oPartDoc As PartDocument
Set oPartDoc = oApp.ActiveDocument
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
Dim oSB As SurfaceBody
Set oSB = oCompDef.SurfaceBodies.Item(1)
oSB.Name = "Panel"
Dim oFacesCol As FaceCollection
Set oFacesCol = oApp.TransientObjects.CreateFaceCollection
Dim oFace As Face
For Each oFace In oSB.Faces
    Call oFacesCol.Add(oFace)
Next
Dim oThickFeat As ThickenFeature
For Each oFace In oFacesCol
    Dim oFaceCol As FaceCollection
    Set oFaceCol = oApp.TransientObjects.CreateFaceCollection
    Call oFaceCol.Add(oFace)
    Set oThickFeat = oCompDef.Features.ThickenFeatures.Add(oFaceCol, "1", PartFeatureExtentDirectionEnum.kNegativeExtentDirection, PartFeatureOperationEnum.kNewBodyOperation, False)
Next
End Sub
R. Krieg
RKW Solutions
Message 8 of 11
Khoa_NguyenDang
It also a idead, Le's i tried it
Message 9 of 11
Khoa_NguyenDang
thank for your idead, let i try it
Message 10 of 11
Khoa_NguyenDang
Hi @Ralf_Krieg
The same problem although I tried your solution
My code
FaceCollection FacesCol = _invApp.TransientObjects.CreateFaceCollection();
foreach (Face face in VNKcol)
FacesCol.Add(face);
foreach(Face f in FacesCol)
FaceCollection FaceCol = _invApp.TransientObjects.CreateFaceCollection();
FaceCol.Add(f);
oThickFeat = partDef.Features.ThickenFeatures.Add(FaceCol, "1mm", PartFeatureExtentDirectionEnum.kNegativeExtentDirection, PartFeatureOperationEnum.kNewBodyOperation, true);
Do you have any other method
Message 11 of 11
Ralf_Krieg
Hello
Sorry, no other method so far.
Does this happen also with the simple rectangular part you posted above? Is the model up to date at the time you try to create the features? Can you try to call a document.update right before you create the first face collection?
I've tried this with the VBA code multiple times without any error.
R. Krieg
RKW Solutions
