Inventor API Open drawing and later resolve file ?
frank_schalla
frank_schalla
Hello to all.
I have a problem that i dont find any way at the moment over the IV2019 API (or i missed something).
Following Scenario i have.
1) We open a drawing during a automation task (Conversion Engine Teamcenter (DISPATCHER))
2) Some taslk are now done (stamping/conversion/ and so on)
3) Now we want to create a combined 2D/3D DWF for the shop floor people.
The problem is that we now must do activate the "Resolfe File" inside Inventor.
In the attached picture you can see what i mean.
We can not use the Deferred_Update = false
Any ideas how i can set this Resolve_Files = true state
chandra.shekar.g
Autodesk Support
Autodesk Support
@frank_schalla,
Try below VBA code to resolve file
Sub StartFileResolve()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oModelPanel As BrowserPane
    Set oModelPanel = oDoc.BrowserPanes("DlHierarchy")
    oDoc.SelectSet.Clear
    oModelPanel.TopNode.DoSelect
     Dim oCommand As ControlDefinition
     Set oCommand = ThisApplication.CommandManager.ControlDefinitions("UCxResolveFileCmd")
     oCommand.Execute
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
frank_schalla
Hello CHANDRA
Thank's for your help it workes fine.
But it's still strange that there is no document get/set property like
Resolved_Files = true/false
chandra.shekar.g
Autodesk Support
Autodesk Support
@frank_schalla,
It seems like a new wish list. Please post this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
