Inventor API: Get the Volume of Surfacebody in MultiSolid IPT File
Khoa_NguyenDang
Khoa_NguyenDang
Hi all guys, does anybody had got the Volume property of the Surfacebody (Solid) in the Multisolid IPT File
Like in the picture
Please help me in this case if you have a solution
Thank you so much
Updating Media
Accepted solutions (3)
CGBenner
@Khoa_NguyenDang
Your image did not fully load.
Chris Benner
J-Camper
@Khoa_NguyenDang
This will display the volume of each Solidbody in a part document:
Sub Main
	If ThisApplication.ActiveDocumentType <> kPartDocumentObject Then MessageBox.Show("This rule is designed to only work in part documents.", "Wrong Document Type") : Exit Sub
	Dim pDef As PartComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
	If pDef.SurfaceBodies.Count < 1 Then MessageBox.Show("No Solids Exist", "Termination") : Exit Sub
	For Each sb As SurfaceBody In pDef.SurfaceBodies
		MessageBox.Show("Internal Calculation [cm^3]: " & Round(sb.Volume(0.0001), 5) & vbCrLf & _
						"Converted Calculation [in^3]: " & Round((sb.Volume(0.0001)/(2.54^3)), 5)	, "Volume for " & sb.Name & ":")
	Next
End Sub
Let me know if you have any questions.
Khoa_NguyenDang
@CGBenner thank for you remind
I attach the picture here
If you have the solution, please help me for this
Khoa_NguyenDang
@J-Camper
Thank for you help, i see you use the below code to get the volume, so when is the Round method you use, I use C# so do you have a sample code in C#
 Thank and wait for your reply
J-Camper
@Khoa_NguyenDang
I'm not familiar enough with C# to tell you how to round a variable, but Round(###, 5) rounds a number to 5 decimal places.   You can take Round(..., 5) out and just use:
sb.Volume(0.0001)
It will just have roughly 10 decimal places, but I'm not sure if that will let you use it in C#
