Inventor API - C# - ComponentOccurences one level lower
christoph.steidle
christoph.steidle
Hello all,
I have a question regarding access via the INventor API.
I use VisualStudio Class Library with .NET 6.0 to access the API.
If I read here in the forum, you always access ComponentDefinition this way.
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
' Get the definition of the assembly.
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = oAsmDoc.ComponentDefinition
For me in VS, it would look like this.
var _inventor = (Inventor.Application)obj;
var _document = _inventor.ActiveDocument;
var _componentDefinition = _document.CompnentDefinition;
Unfortunately, this does not work for me so to access it I have to go one level higher which I do not understand and therefore does not work as intended?
foreach (Document refDoc in _document.AllReferencedDocuments)
if (refDoc.DocumentType == DocumentTypeEnum.kPartDocumentObject)
       var doc = (PartDocument)refDoc;
       var _doc.Add((doc )refDoc);
foreach (ComponentOccurrence occurence in _doc[i].ComponentDefinition.Occurrences)
I would be very grateful for your help or an explanation.
Greetings
Ralf_Krieg
Hello
Just a typo?
vs.
var _componentDefinition = _document.ComponentDefinition;
R. Krieg
RKW Solutions
www.rkw-solutions.com
christoph.steidle
thanks for your answer but I don't exactly understand what you mean?
var _componentDefinition1 = _document.ComponentDefinition;
var _componentDefinition2 = _doc[0].ComponentDefinition;
As you could see in the picture only the third line is an accessible method?
Ralf_Krieg
Hello
Meant that in the line I posted, an "o" in Component was missing.
Anyway, your problem is, that _document is a generic document type. This includes drawings too and drawings don't have a ComponentDefinition. Cast _document as AssemblyDocument (if prechecked it is an assembly) and the error should disappear.
_doc[0] is a referenced document (part or subassembly) in your assembly. As all docs in _doc are casted as PartDocuments, you don't get an error of the missing Componentdefinition object. PartDocument always have a ComponentDefinition. But, a referenced document could also be an assembly, so this way the next error is just one step away.
R. Krieg
RKW Solutions
