inventor and AutoCAD dwg file difference
Hi
I'm looping through files in a folder/subfolders with VBA and collecting iproperties, but I get an error when I hit an AutoCAD dwg.  the error handler doesn't seem to pick it up
any ideas?
I am not sure on VBA. But using .Net API you can use "FileManager.IsInventorDWG". This might help you.
I tried this last year with Apprentice Server(Inventor 2013) & C#.
Hope it might help
figured my  problem out, I had break on all errors selected instead of on unhandled errors
Thanks, just saw your reply, as I submitted the sol to my problem.
I've implemented yours it and it works, so no need for error handling.
Dim ApApprentice As New ApprenticeServerComponent
Dim filToProcess As Scripting.File
If ApApprentice.FileManager.IsInventorDWG(filToProcess.Path) Then
