Inventor 2025 issue with existing iLogic rule
chrisw01a
chrisw01a
Curtis wrote this and it works wonderfully however it does not like the new 2025.1. It looks like it's trying to call an executable but it's not providing the correct name or something...Any ideas?
Here is the error:
'REV 10 (10/10/23)
'verify document type
If ThisApplication.ActiveDocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
	'MessageBox.Show("Document Type: " & ThisApplication.ActiveDocumentType.ToString)
	MessageBox.Show("Must be run from an Assembly! Program will now exit.")
	Exit Sub
areaAdder = 1.50 'add % to area calc to account for drop cw
oPath = ThisDoc.WorkspacePath()
oJob = oPath.Substring(oPath.LastIndexOf("\") + 1)
'oLogFile = oPath & "\Material Usage.txt"
oLogFile = oPath & "\" & oJob & "_Material.txt"
'MessageBox.Show(oLogFile)
'uncomment/comment to change suffix format
sSuffix = " sq feet"
'sSuffix = " ft^2"
'sSuffix = " sq inch"
'sSuffix = " in^2"
'uncomment/comment to change conversion factor
oConversion_factor = 929.03 'cm to feet
'oConversion_factor = 6.4516 'cm to inch
'uncomment/comment to change tab spacing in output file
sSpacer = vbTab
'create log file if it does not exist
If System.IO.File.Exists(oLogFile) Then
	System.IO.File.Delete(oLogFile)
'create log file
Dim oStreamWriter As System.IO.StreamWriter
oStreamWriter = IO.File.CreateText(oLogFile)
'oStreamWriter.WriteLine(Now())
oStreamWriter.WriteLine("")
oStreamWriter.WriteLine("Totals for ONE unit" & " + " & ((areaAdder - 1) * 100) & "%") 'cw
oStreamWriter.Close()
'[ look at each component
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As ComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oMatList As New ArrayList
Dim oUniqueList As New ArrayList
Dim oFinalList As New ArrayList
Dim dArea As Double
'iterate through all lowest level occurrences (parts)
For Each oOcc In oAsmCompDef.Occurrences.AllLeafOccurrences
	'MessageBox.Show(oOcc.Name)
	'if component occurrence is suppressed, skip to next component
	If oOcc.Suppressed Then
		'MessageBox.Show(oOcc.Name & " supressed")
		Continue For
	Dim oDoc As PartDocument
	oDoc = oOcc.Definition.Document
	Dim oUOM As UnitsOfMeasure
	oUOM = oDoc.UnitsOfMeasure
	'ensure this part is a Sheet Metal Part
	If Not oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
		'MessageBox.Show("Part is not a Sheet Metal Part: " & oDoc.FullFileName)
		Continue For
	Dim oDef As SheetMetalComponentDefinition
	oDef = oDoc.ComponentDefinition
	oMat = oDef.Material
	'MessageBox.Show(oMat.Name, "debug")
	'Don't skip if certain materials
	If Not UCase(oMat.Name) = "CERAMIC TILE" And Not UCase(oMat.Name) = "CBU" And Not UCase(oMat.Name) = "CBUHE" And Not UCase(oMat.Name) = "EMBU" Then
		'skip if x
		If UCase(iProperties.Value(oOcc.Name, "Summary", "Keywords")) = "X" Then
			Continue For
	oPrecision = oUOM.LengthDisplayPrecision 'get current precision
	oUOM.LengthDisplayPrecision = 4 'set to 4 places
	oThick = oDef.Parameters.Item("Thickness").Value
	'MessageBox.Show(oThick, "debug")
	oThick = oUOM.GetStringFromValue(oThick, "in")
	oThick = oThick.Replace(Right(oThick, 3), "") ' remove unit string
	oThick = CDblAny(oThick) 'convert back to number
	oThick = FormatNumber(oThick, 4, , , TriState.True) ' format
	oUOM.LengthDisplayPrecision = oPrecision 'set precision back
	'only add to list if it is unique
	If Not oUniqueList.Contains(oMat.Name & " " & oThick) Then
		oUniqueList.Add(oMat.Name & " " & oThick)
	Dim oTransaction As Transaction
	oTransaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "Find area")
	'create flat pattern if none exist
	If oDef.FlatPattern Is Nothing Then
		Dim openedView As Inventor.View = Nothing
		If oDoc IsNot ThisApplication.ActiveDocument Then
			openedView = oDoc.Views.Add()
			oDoc.Activate()
		Try
			oDef.Unfold
			'close flat pattern
			oDef.FlatPattern.ExitEdit
			If openedView IsNot Nothing Then
				openedView.Close()
		Catch
			MessageBox.Show("Can't create flat pattern for: " & oDoc.FullDocumentName & vbCr & "Program will now exit.")
			Exit Sub
		End Try
	Dim oFlatPattern As FlatPattern
	oFlatPattern = oDef.FlatPattern
	Dim oFlatFeatures As FlatPatternFeatures
	oFlatFeatures = oFlatPattern.Features
	'Create an Object collection To add the features For suppression
	Dim oFeatCollection As ObjectCollection
	oFeatCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For Each oFeat In oFlatFeatures
		If oFeat.Suppressed = False Then
			'Add feature to suppress to the collection
			oFeatCollection.Add(oFeat)
	Next
	'suppress everything in this collection
	Try
		oDef.FlatPattern.SuppressFeatures(oFeatCollection)
	Catch
	End Try
	'MessageBox.Show("Debug1")
	'[ get area
	Try
		Dim oSketch As PlanarSketch
		oSketch = oFlatPattern.Sketches.Add(oFlatPattern.TopFace)
		Dim oEdgeLoop As EdgeLoop
		For Each oEdgeLoop In oFlatPattern.TopFace.EdgeLoops
			If oEdgeLoop.IsOuterEdgeLoop Then
				Exit For
		Next
		Dim oEdge As Edge
		For Each oEdge In oEdgeLoop.Edges
			oSketch.AddByProjectingEntity(oEdge)
		Next
		Dim oProfile As Profile
		oProfile = oSketch.Profiles.AddForSolid
		dArea = oProfile.RegionProperties.Area
		sArea = Round(dArea, 3) * areaAdder
		'MessageBox.Show("oMatlist.Add: " & oDef.Document.FullFileName)
		oMatList.Add(oMat.Name & " " & oThick & "|" & sArea)
		oTransaction.Abort
	Catch
		MessageBox.Show("Failed to create sketch: " & oDef.Document.FullFileName & vbCr & oDef.Document.FullDocumentName & vbCr & "Program will now exit.")
		Exit Sub
	End Try
Next
'[ total areas for same materials
Dim dTotal As Double
Dim sName As String
Dim sPartNumber As String
'get max of mat & thickness string
sMatNameLen_Max = 0
For Each sName In oUniqueList
	'capture max mat name length
	sMatNameLen = Len(sName)
	If sMatNameLen > sMatNameLen_Max Then
		sMatNameLen_Max = sMatNameLen
Next
'add header dash line calc'd on max mat name length
sDash = "-"
For i = 0 To sMatNameLen_Max + 30 + 10
	sDash = sDash & "-"
Next
'amend log file
oStreamWriter = IO.File.AppendText(oLogFile)
oStreamWriter.WriteLine(sDash)
oStreamWriter.Flush()
	For Each oItem in oMatList
		'split using char
		Dim sMat_Area As String() = oItem.Split(New Char() {"|"c })
		sMat = sMat_Area(0)
		sArea = sMat_Area(1)
		dArea = CDblAny(sArea) 'get number as a double
		If sMat = sName Then
			dTotal = dTotal + dArea
			sTotal = Round(dTotal / oConversion_factor, 3)
			sTotal = FormatNumber(sTotal, 3, , , TriState.True) & sSuffix ' format
	Next
	'Trace.WriteLine(sName, "iLogic") 'debug
	'Trace.WriteLine(sMatNameLen_Max, "iLogic") 'debug
	'Trace.WriteLine(Len(sName)	, "iLogic") 'debug
	'calc the number of spaces to add
	oNamePad = sMatNameLen_Max - Len(sName)
	oPad = ""
	For k = 0 To oNamePad
		oPad = oPad & " "
	Next
	'Supply the stock sheet part#
	Select Case sName
		Case "Steel Mild 0.0747"
			sPartNumber = "800003"
		Case "Steel Mild 0.1046"
			sPartNumber = "800005"
		Case "Steel Mild 0.1345"
			sPartNumber = "800007"
		Case "Steel Mild 0.1875"
			sPartNumber = "801001"
		Case "Steel Mild 0.2500"
			sPartNumber = "801002"
		Case "Steel Mild 0.3750"
			sPartNumber = "801004"
		Case "Steel Mild 0.5000"
			sPartNumber = "801005"
		Case "Steel Mild 0.6250"
			sPartNumber = "801009"
		Case "Stainless Steel 0.0747"
			sPartNumber = "800303"
		Case "Stainless Steel 0.1046"
			sPartNumber = "800304"
		Case "Stainless Steel 0.1345"
			sPartNumber = "800305"
		Case "Stainless Steel 0.1875"
			sPartNumber = "801101"
		Case "Stainless Steel 0.2500"
			sPartNumber = "801103"
		Case "Stainless Steel 0.3750"
			sPartNumber = "801104"
		Case "AR 0.1345"
			sPartNumber = "802510"
		Case "AR 0.1875"
			sPartNumber = "802502"
		Case "AR 0.2500"
			sPartNumber = "802504"
		Case "Galvanized 0.1046"
			sPartNumber = "800152"
		Case "CBU 0.2500"
			sPartNumber = "800511"
		Case "CBUHE 0.2500"
			sPartNumber = "800523"
		Case "EMBU 0.2500"
			sPartNumber = "800509"
		Case "CERAMIC TILE 0.2500"
			sPartNumber = "HEX:800600 4X6:800602"
		Case Else
			sPartNumber = "xxxxxx"
	End Select
	'amend log file
	oMessageLine1 = sName & oPad & "  (" & sPartNumber & ")" & sSpacer & ":" & sSpacer & sTotal
	oStreamWriter.WriteLine(oMessageLine1)
	dTotal = 0
Next
Process.Start(oLogFile)
WCrihfield
Hi @chrisw01a.  I have not updated from 2024.2 to 2025 yet, so I can not test, but you could try changing this following line:
with this one
ThisDoc.Launch(oLogFile)
It too will return a 'Process' type object, if used as a Function, and capturing it to a variable, but it looks like that is not important in this task.  This is just the normal iLogic shortcut snippet for either opening a file, or starting some other application, but sounds like it may do essentially the same thing.  It may have some extra support from the iLogic add-in in the background to help though.
Wesley Crihfield
(Not an Autodesk Employee)
chrisw01a
You have fixed it. Thank you very much!
WCrihfield
Hi @chrisw01a.  Just pointing out something important that you should know about.  Another very similar forum topic was created shortly after yours, mentioning the same exact issue that you were experiencing.  Someone from Autodesk explained the situation, then offered a better solution for how to fix it for future (Inventor 2025 and later) development.  I will post a link to that main forum topic below, so that you (and others who find this topic later) can find the same, better solution.
https://forums.autodesk.com/t5/inventor-programming-ilogic/fail-to-use-process-start-in-inventor-202...
Wesley Crihfield
chrisw01a
Thank you. This information is pressing up to the edge of my understanding but I'll read it again when I have a clear mind. Should I expect the "ThisDoc.Launch(oLogFile)" to quit working?
WCrihfield
I have not heard anything about the 'ThisDoc.Launch' method loosing any support.  However, it is an iLogic only resource, and designed with Inventor in mind, so its usefulness is mostly limited to being used within iLogic rules.  The Process.Start method is defined within the .NET system, so it is usable in more places.  Those seem to be the main differences.  Those who write code for things like Inventor add-ins or standalone applications tend to prefer using resources that are not dependent on the iLogic add-in.
Wesley Crihfield
chrisw01a
Understood. Thanks again!
