Inventor 2023: Access a member create with the frame generator
Sébastien_G
Sébastien_G
Dear All,
Here is the context in which I work.
I am in a General Assembly that is composed of part, welded construction and frame generated by the Frame Generator.
The question is how to reach the angle (in my case) with an iLogic code.
The code should look something like this
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oCompDef As Componentdefinition = ...
I have to go to the angle with the API objects.
I am listening to your proposals
@Sébastien_G
JelteDeJong
You did not specify if you wanted to get that occurrence or the document of that occurrence. If you want to get the document and you have a unique "Part number" then this could get you the document.
Dim doc As AssemblyDocument = ThisDoc.Document
Dim refDoc = doc.AllReferencedDocuments.Cast(Of Document).
    FirstOrDefault(Function(d) d.PropertySets("Design Tracking Properties")("Part Number").Value.Equals("<Your part number here>"))
If (refDoc Is Nothing) Then
    MsgBox("document was not found")
Else
    MsgBox("You found the document: " & refDoc.FullDocumentName)
Jelte de Jong
Blog: hjalte.nl - github.com
JelteDeJong
or if you want to find the occurrence then you could try this.
Sub Main()
    Dim occ = GetOccurence(doc.ComponentDefinition.Occurrences, "<Occurence name here>")
    If (occ Is Nothing) Then
        MsgBox("Occurence was not found")
    Else
        MsgBox("You found the Occurence: " & occ.Name)
End Sub
Public Function GetOccurence(Occurrences As ComponentOccurrences, name As String) As ComponentOccurrence
    For Each occ As ComponentOccurrence In Occurrences
        If (occ.Name.Equals(name)) Then
            Return occ
        If (occ.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then
            Dim foundOcc = GetOccurence(occ.Definition.Occurrences, name)
            If (foundOcc IsNot Nothing) Then
                Return foundOcc
    Next
    Return Nothing
End Function
This is the complicated way but will find all occurrences including sub-assemblies.
Jelte de Jong
JelteDeJong
Or if you don't care if you can't find subassemblies occurrences then you could try this:
Dim occ = doc.ComponentDefinition.Occurrences.
    AllLeafOccurrences.Cast(Of ComponentOccurrence).
    FirstOrDefault(Function(o) o.Name.Equals("<Occurence name here>"))
Else
Jelte de Jong
Sébastien_G
Hello Jelte,
In fact, I’m trying to reach the Material iProperty of the Angle.
I’m trying to perform the same function I asked you for help on a few days ago.
