Inventor 2022 addin hangs after selection of several objects
M.Zirk
Message 1 of 1
M.Zirk
after changing Inventorinterop from 26.0 to 26.1 I have problems with the selection of objects.
For example the preselect event.
In an  idw it takes up to 60 seconds until Inventor reacts again.
The event is fired then I try to inspect the selection.
After selection I inspect the selection object to find out what object type i got.
If it is the desired one then I do somenthing with the object.
It makes no difference if the selection was made in the modelbrowser or direcht in the sheet.
I get no errors or something but it takes 60 s or more until I can go on.
The same occurs in IAMs.
Going back to version 26.0 of the Inventorinterop evrything works fine again.
So I think the problem is in the new release.
Manfred
Replies (0)
