Inventor 2020 3D modelling - model and vault browser
autodesk-MM
autodesk-MM
Hello all,
Not sure if this is a bug or a setting. Every time I extrude sketch( or revolve etc.)
 it goes from Model  to Vault browser as per screen cast. This is very annoying, anyone came across?
P.S.
Autodesk I hate your bright theme! MY EYES ARE IN PAIN EVERYDAY SINCE UPGRADE!!!! PLEASE ADD UI CUSTOMISATION!!
YuhanZhang
Can you capture a video for the issue? This may help us to reproduce the problem and find the reason. Also can you reproduce this issue if you unload all the addins except the Vault, this can help to narrow if some addin may cause the problem.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
autodesk-MM
Tried to add a screen cast with the first post but it doesn't seem to load correctly. Hopefully this time...
YuhanZhang
I got it. So I think the problem is because the Properties panel is docked in the same browser as the Model, and then when you click OK in the extrude feature Properties panel it switch to the nearest panel(which is the Vault in your case). To avoid this you can try to create an extrusion, and drag the Properties panel to dock to the right of the Model browser but not in it, then next time when you close the Properties the active panel will be the Model again:
Rocky Zhang
Inventor API PD
Autodesk, Inc.
autodesk-MM
Dragging and docking  properties tab before the model tab solves the problem in the current session only. You have to do it every time you open new inventor session.
