Inventor 2014 Asset Description
Is it possiable to create or edit Description, Type and Keywords of asset through API. (see attached for detail)
If Yes, what will be the value type and value name of asset description?
No reply from Autodesk Team?
xiaodong_liang
Autodesk Support
Autodesk Support
I think it should work if the Asset which has been added to the document. an API sample demos how to change “generic_diffuse”. So I thought it would be like below if changing description like this:
oAsset.Item("description").Value = "my desc"
But, it does now work. Dumping all values of an Asset, I found no “description” item.
I logged this issue #1510281
Thank you for the reply and logging the issue.
You mean :  it does now work. or it does not work?
I tried and gives error.
xiaodong_liang
Autodesk Support
Autodesk Support
oops, a typo!
It does NOT work. It failed at this line. Sorry.
Sorry to raise an old thread, but it's been a year and a half (two inventor versions!), and this problem is still present for appearance assets. How can we find out the status of the logged issue?
