Inventor 11 links
Inventor 11 links
Inventor 11 links
Our drawing files have a link to a *.bmp logo file. Unfortunately, the server with that file has been removed from service. When we open old drawing files, Inventor searches for up to 2 hours before offering a resolution. Does anyone have a VBA method for disolving the link?
The macro below opens a drawing in "silent" mode and deletes all the missing
OLE references from it. If the logo was embedded in a titleblock, Inventor
will put up a "file missing" message the next time you edit the titleblock
definition.
Sanjay-
Sub DeleteMissingReferences()
ThisApplication.SilentOperation = True
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.Documents.Open("C:\temp\junk.idw")
Dim oOLEFileDescriptor As ReferencedOLEFileDescriptor
For Each oOLEFileDescriptor In oDoc.ReferencedOLEFileDescriptors
If oOLEFileDescriptor.ReferenceStatus = kMissingReference Then
oOLEFileDescriptor.Delete
Next
ThisApplication.SilentOperation = False
End Sub
wrote in message news:5733834@discussion.autodesk.com...
Thank you very much. I took a few weeks to make sure your solution works in our drawings. I have added an error trapping move and tell VBA to print the drawings so the user can see that the bitmap is removed. I also use an input box to request an entire folder to work on at one time. Inventor still takes a very long time opening the files, but this is one program that can be run at night when we go home.
Mark_Wigan
hello, would you still have the ammended code that you generated for this? i have to do some batch processing on a lot of files with incorrect logo paths.
many thanks.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
