Intersection points of Sketchentities
How to get Intersection points of 2D Sketch Entities?
Problem:
if we select two entities(which are curved entities) then how to get the intersection points of the entities?
Thanks in advance
regards,
SasiRajesh
Good question.
The API does not currently support general curve-curve intersection. There
is support for line-curve intersection. The various Line objects support
the IntersectWithCurve method. Curve-curve intersection is something we
need to do.
Brian Ekins
Autodesk Inventor API
This problem can be solved (with some limitations) by minimization of the distance between two points on two curves till it is less than user defined tolerance.
Limitations originate from possibility of multiple intersections. With simple two-dimensional minimization it will be difficult to localize all intersection points. Message was edited by: ALink
The following code is my attempt to find the intersection point in case of two splines. It is not the best method, There are a lot of limitations (see above). But I hope this gives you an idea. This code is for tests only, because of very limited testing.
ALink
Public Sub Spline_Intersection_Sample()
'Setup important user-defined parameters:
'1) tolerance
Dim AbsTol As Double 'absolute tolerance in cm
AbsTol = 0.000001 ' <=== absolute deviation <= 0.01 mkm
'2) dimension of initial spline fragmentation
Dim N As Long
N = 100
'3) Upper limit for the quantity of iteration loops (for safety)
Dim ITERATIONS_MAX_LIMIT As Long
ITERATIONS_MAX_LIMIT = 1000
'Basic preparations
'Основные приготовления
'reference to Transient Geometry
'ссылка на вспомогательную геометрию
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
'reference to the 1st sketch (for simplicity)
'ссылка на первый эскиз
Dim oActiveSketch As PlanarSketch
Set oActiveSketch = ThisApplication.ActiveDocument. _
ComponentDefinition.Sketches.Item(1)
'reference to SketchPoints collection in oActiveSketch
'ссылка на коллекцию эскизных точек в активном эскизе
Dim oSketchPoints As SketchPoints
Set oSketchPoints = oActiveSketch.SketchPoints
'In this example we'll use two first splines.
'Be sure you have at least two splines.
'Здесь для простоты используем два первых сплайна эскиза
'Убедитесь, что в эскизе есть хотя бы два сплайна)
Dim oSpline1 As SketchSpline
Dim oSpline2 As SketchSpline
Set oSpline1 = oActiveSketch.SketchSplines(1)
Set oSpline2 = oActiveSketch.SketchSplines(2)
'evaluator of the first curve
'ссылка на вычислитель сплайна 1
Dim oCurve2dEvaluator1 As Curve2dEvaluator
Set oCurve2dEvaluator1 = oSpline1.Geometry.Evaluator
'evaluator of the second curve
'ссылка на вычислитель сплайна 2
Dim oCurve2dEvaluator2 As Curve2dEvaluator
Set oCurve2dEvaluator2 = oSpline2.Geometry.Evaluator
Dim Distance As Double
Dim oPoint2d1 As Point2d
Dim oPoint2d2 As Point2d
Dim IterationFact As Long
'call minimization procedure
Call FindIntersection_3( _
oCurve2dEvaluator1, _
oCurve2dEvaluator2, _
AbsTol, _
N, _
ITERATIONS_MAX_LIMIT, _
IterationFact, _
Distance, _
oPoint2d1, _
oPoint2d2)
'let us know if maximum iteration limit was exceeded
'possibly we have a problem
If IterationFact > ITERATIONS_MAX_LIMIT Then
MsgBox "Maximum iteration limit was exceeded." & vbNewLine _
& "Stopped at: " & IterationFact & " iterations"
'ставим эскизную точку на кривой 1
'put sketch point on curve 1
Dim oP As SketchPoint
Set oP = oSketchPoints.Add(oPoint2d1, False)
MsgBox "Dist = " & Round(Distance * 10, 8) & " mm" & vbNewLine & _
"Iterations = " & IterationFact
End Sub 'Spline_Intersection_Sample
' FindIntersection_3
Private Sub FindIntersection_3( _
ByRef oCurve2dEvaluator1 As Curve2dEvaluator, _
ByRef oCurve2dEvaluator2 As Curve2dEvaluator, _
ByVal AbsTol As Double, _
ByVal N As Long, _
ByVal ITERATIONS_MAX_LIMIT As Long, _
ByRef IterationFact As Long, _
ByRef Distance As Double, _
ByRef oPoint2d1 As Point2d, _
ByRef oPoint2d2 As Point2d)
'parameter range for the 1st curve
'вычислим границы диапазона изменения параметра кривой 1
Dim Param1_Min As Double
Dim Param1_Max As Double
Call oCurve2dEvaluator1.GetParamExtents(Param1_Min, Param1_Max)
'parameter range for the 2nd curve
'вычислим границы диапазона изменения параметра кривой 2
Dim Param2_Min As Double
Dim Param2_Max As Double
Call oCurve2dEvaluator2.GetParamExtents(Param2_Min, Param2_Max)
'Step 1. A rough approximation for start points
'Шаг 1. Грубое начальное приближение для точки пересечения
Dim i As Long, j As Long
Dim x1 As Double
Dim x2 As Double
Dim y1 As Double
Dim y2 As Double
Dim dParams(0 To 0) As Double
Dim dPointsCoord() As Double
Dim Coord1() As Double
Dim Coord2() As Double
ReDim Coord1(0 To N, 1 To 2) 'arrays for coordinates
ReDim Coord2(0 To N, 1 To 2)
For i = 0 To N
dParams(0) = Param1_Min + i * (Param1_Max - Param1_Min) / N
Call oCurve2dEvaluator1.GetPointAtParam(dParams, dPointsCoord)
'запоминаем координаты точки i
'save coordinates for index i
Coord1(i, 1) = dPointsCoord(0)
Coord1(i, 2) = dPointsCoord(1)
Next i
For j = 0 To N
dParams(0) = Param2_Min + j * (Param2_Max - Param2_Min) / N
Call oCurve2dEvaluator2.GetPointAtParam(dParams, dPointsCoord)
'запоминаем координаты точки j
'save coordinates for index j
Coord2(j, 1) = dPointsCoord(0)
Coord2(j, 2) = dPointsCoord(1)
Next j
Dim Min As Double
Dim n1 As Long
Dim n2 As Long
Dim Dist As Double
Min = 1E+199: n1 = -1: n2 = -1 ' initial values
For i = 0 To N
For j = 0 To N
Dist = Sqr((Coord1(i, 1) - Coord2(j, 1)) ^ 2 + _
(Coord1(i, 2) - Coord2(j, 2)) ^ 2)
If Dist < Min Then
Min = Dist
n1 = i
n2 = j
Next j
Next i
'Step 2. Find intersection point
'Шаг 2. Итерационный поиск точки пересечения
' %%%%%%%%%% Start %%%%%%%%%%
' %%%%%%%%%% Minimization %%%%%%%%%%
Dim p(0 To 8, 1 To 2) As Double 'cube vertex array
Dim D(0 To 8) As Double 'distances for each cube vertex
Dim Delta As Double 'cube size parameter
Dim IterCounter As Long 'loop counter
IterCounter = -1
'initial cube half size
Delta = (Param1_Max - Param1_Min + Param2_Max - Param2_Min) / N / 3
'cube center -- "vertex" #0
p(0, 1) = Param1_Min + n1 * (Param1_Max - Param1_Min) / N
p(0, 2) = Param2_Min + n2 * (Param2_Max - Param2_Min) / N
'~~~~~ Start Iterations ~~~~~
Do
IterCounter = IterCounter + 1 'iteration number
'vertex 1
p(1, 1) = p(0, 1) + Delta
p(1, 2) = p(0, 2)
'vertex 2
p(2, 1) = p(0, 1) + Delta
p(2, 2) = p(0, 2) + Delta
'vertex 3
p(3, 1) = p(0, 1)
p(3, 2) = p(0, 2) + Delta
'vertex 4
p(4, 1) = p(0, 1) - Delta
p(4, 2) = p(0, 2) + Delta
'vertex 5
p(5, 1) = p(0, 1) - Delta
p(5, 2) = p(0, 2)
'vertex 6
p(6, 1) = p(0, 1) - Delta
p(6, 2) = p(0, 2) - Delta
'vertex 7
p(7, 1) = p(0, 1)
p(7, 2) = p(0, 2) - Delta
'vertex 8
p(8, 1) = p(0, 1) + Delta
p(8, 2) = p(0, 2) - Delta
'Calculate distance for each cube vertex (#0..#8)
For i = 0 To 8
D(i) = CalcDistance(oCurve2dEvaluator1, oCurve2dEvaluator2, p(i, 1), p(i, 2))
Next i
'calc minimal distance
Min = D(0)
n1 = 0
For i = 1 To 8
If D(i) < Min Then
Min = D(i)
n1 = i
Next i
'uncomment this line to see iterations in progress
' Debug.Print "Iter="; IterCounter, "Dist,(mm)= "; Min * 10#
If n1 = 0 Then
Delta = Delta * 0.7 'controls cube size
Else
p(0, 1) = p(n1, 1)
p(0, 2) = p(n1, 2)
'move cube center to the vertex n1 (with min distance)
Loop Until (Min < AbsTol) Or (IterCounter > ITERATIONS_MAX_LIMIT)
'~~~~~ Stop iterations ~~~~
Distance = Min 'output
IterationFact = IterCounter 'output
'Calculate 1-st point coordinates
dParams(0) = p(0, 1)
'создаем 2d точки для вызывающей процедуры
'create output 2d point for curve 1
Set oPoint2d1 = oTG.CreatePoint2d(dPointsCoord(0), dPointsCoord(1))
'Calculate 2-nd point coordinates
dParams(0) = p(0, 2)
'create output 2d point for curve 2
Set oPoint2d2 = oTG.CreatePoint2d(dPointsCoord(0), dPointsCoord(1))
End Sub 'FindIntersection_3
Private Function CalcDistance( _
ByVal param1 As Double, _
ByVal param2 As Double) As Double
Dim x1 As Double
Dim x2 As Double
Dim y1 As Double
Dim y2 As Double
'Calculate 1-st point coordinates (curve 1)
dParams(0) = param1
x1 = dPointsCoord(0)
y1 = dPointsCoord(1)
'Calculate 2-nd point coordinates (curve 2)
dParams(0) = param2
x2 = dPointsCoord(0)
y2 = dPointsCoord(1)
'distance between two points (cm)
CalcDistance = Sqr((x1 - x2) ^ 2 + (y1 - y2) ^ 2)
End Function 'CalcDistance
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Message was edited by: ALink
KISS principle lead me to better solution which use INVENTOR’s internal optimization mathematics.
This example also finds the intersection (if any) between two given planar splines.
This program:
1. Generates N points belongs each given spline, finds two closest points and uses the first one as initial position of the intersection point.
2. Grounds both splines.
3. Put new sketch point into this position.
4. Constraints it with the 1st spline (coincidence).
5. Constraints it with the 2nd spline (coincidence). If successful it’s a desired intersection.
6. Restores constraint status for all fit points in both splines.
If it is no error then intersection was found, constrained sketch point indicates intersection point.
Unsuccessful initial position can prevent to find desired point even when intersection really exists (like local minimum can prevent to find the global one). You may test this manually in GUI repeating steps 3..5.
In this case you may try to increase fragmentation parameter N.
I like this method more than posted previously.
See attachment.
ALink
