Interrupting component placement after first occurrence is placed
j.haggenjos
j.haggenjos
Hello all,
I'm developing an Add-In and I am facing an issue.
At some point in the process, I am placing a part with user interaction. The component placement is working correctly.
However, until the user hits the escape key or "right-click -> Done", each click will place a new occurrence of the component. I would like to prevent the user of placing multiple component.
In my main routine, I am using the command manager to place a component:
CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, FilePath)
CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute()
And using the OnNewOccurrence event handler I am trying to stop the command after the first item is placed.
I have tried the following:
Private Sub AssemblyEvents_OnNewOccurrence(...) Handles AssemblyEvents.OnNewOccurrence
    If BeforeOrAfter = EventTimingEnum.kAfter Then
        CommandManager.StopActiveCommand()
        'This will throw an exception
        CommandManager.ControlDefinitions.Item("AppContextual_DoneCmd").Execute()
        CommandManager.ControlDefinitions.Item("AppContextual_CancelCmd").Execute()
        CommandManager.ControlDefinitions.Item("AppContextual_OKCmd").Execute()
        'Those three command seem to have no effect
End Sub
Is there any way to stop the AssemblyPlaceComponentCmd with the API?
WCrihfield
Here are a couple more commands you can try:
"Done"
"AppNGX_CancelCmd" (cancels the command)
"AppNGX_OKCmd"  (commits the command)
Other than that, all I can think of is either using the SendKeys.SendWait("{ESC}") technique (which you may need to make sure you have the 'focus' of that dialog before using), or not using the command to invoke the built-in tool for adding components, and attempt to do it in a different way.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
Wesley Crihfield
(Not an Autodesk Employee)
j.haggenjos
Thanks for the answer.
I tried the commands. They had no effect unfortunately.
I had tried simulating the escape key before. Following your post, I tried to make sure the inventor window was in focus. I stumbled upon this post and tried using postmessage. It didn't work either. However, the post also suggest to use:
CommandManager.ControlDefinitions.Item("AppSelectNorthwestArrowCmd").Execute
Which finaly had the result I was looking for. Interestingly, searching for "AppSelectNorthwestArrowCmd" lead me to this post from 2008 with the exact same issue and solution.
Thanks @WCrihfield for pushing me in the right direction with your post.
A special thanks to @ekinsb for his suggestion in the other post and for all the great content available here and elsewhere online.
