Internal names for Appearance Library
floccipier
floccipier
Hi guys,
I am here again shamelessly with another question 😬
How can I find the internal code names for the appearance library items.  Specifically I read in another post that you can assign appearance like this
Dim sourceAppearance As Asset = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9").AppearanceAssets.Item("InvGen-001-1-2") ' "Clear - Blue"
			targetAppearance = sourceAppearance.CopyTo(partDoc)
 and I want to use this method for some of my routines but don't know how to find internal names as used above.
Thank you in advance.
regards,
sam
Ralf_Krieg
Hello
Write out all internal names for the libraries used in the current active project and all included appearance assets to iLogic protocol browser with
Dim oApp As Inventor.Application = ThisApplication
Dim oAssetLib As AssetLibrary
Dim oAsset As Asset
For Each oAssetLib In oApp.AssetLibraries
    Logger.Debug (oAssetLib.DisplayName)
    Logger.Debug (oAssetLib.InternalName)
    'enable to write out asset names
	'For Each oAsset In oAssetLib.AppearanceAssets
    '    Logger.Debug ("     " & oAsset.DisplayName)
    '    Logger.Debug ("     " & oAsset.Name)
    'Next
Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
FINET_Laurent
You could also look trough the Object tree using the VBA editior.
Simply use this code in a new module, put an spy on "ThisApplication" Object and look inside like so :
Tutorial : https://www.youtube.com/watch?v=2ZnR8xBMBpg
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
floccipier
@FINET_Laurent  Thank you.
@Ralf_Krieg  thanks again 🙂
