interaction events not working in addin release build only
prussellZXB3F
prussellZXB3F
I've created an addin which works fine running the debug version of the .dll but not the release version. The event starts but cannot select anything inside the modelling window, no errors, can still use the mouse to select a new command etc. just can't complete the selection event?!
Inventor 2019, VS2017
Using interaction events rather then the .pick() selection method.
Many thanks in advance for any suggestions or ideas
Phil
prussellZXB3F
removed optimisation on the build, gained a couple of kb but works fine now
