installation inventor
rune.vanoost
Observer Observer
rune.vanoost
Observer
Observer
I have a problem with the installation of inventor 2016. the first part of the installation proceeds perfectly but when the installation reaches 6.58GB out of 9.5GB it stops with further installation. in the upper right corner is a loading bar that keeps showing "connecting". I started the installation over for a second time but even then it stops at 6.58GB. Down below you'll find a print screen of my problem.
Could someone help me with this?
kind regards
Rob67ert
Hi Rune,
maybe it helps to first download the complete installation file and install it from there.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Binga
Try downloading from the Virtual Agent: http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
rune.vanoost
Observer
Observer
Thanks for the help. It has been installed completely.
