Inserting autocad DWG OLE object in drawing makes autocad freeze.
Message 1 of 1
Hello.
I've got an iLogic routine that saves the current drawing in DWG and then inserts it as an OLE object.
Most of the time it makes Autocad freeze, so I have to kill the acad process in order to make it work.
Any idea of how to solve it? I paste the code here. Thanks in advance.
If ThisDoc.Path="" Then
MessageBox.Show("Guarde primero el plano", "ERROR")
Else
oPath = ThisDoc.Path
FABRICACION = New String() {"FABRICACION", "NO FABRICACION"}
FABRICACIONELEGIDA= InputListBox("ELEGIR OPCION",FABRICACION, "", "CREADOR DWG", "")
	Select Case FABRICACIONELEGIDA
	Case = "FABRICACION"
		oDIRECTORIOFAB = ThisDoc.Path & "\" & "FABRICACION" & "\"
		If Not System.IO.Directory.Exists(oDIRECTORIOFAB) Then
		System.IO.Directory.CreateDirectory(oDIRECTORIOFAB)
		NOMBREFAB = oDIRECTORIOFAB & ThisDoc.FileName(False) & ".dwg"
		ThisDoc.Document.SaveAs(NOMBREFAB , True)
		oDoc = ThisApplication.ActiveDocument
		Dim kOLEDocumentLinkObject As ObjectTypeEnum
		kOLEDocumentLinkObject = 3331
		Dim oRefOLE As ReferencedOLEFileDescriptors
		oRefOLE = oDoc.ReferencedOLEFileDescriptors
		oRefOLE.Add(NOMBREFAB, kOLEDocumentLinkObject)
		MessageBox.Show("DWG CREADO EN CARPETA FABRICACION", "COMPLETADO")
	Case = "NO FABRICACION"
		NOMBRE = ThisDoc.PathAndFileName(False)  & ".dwg"
		ThisDoc.Document.SaveAs(NOMBRE, True)
		oRefOLE.Add(NOMBRE, kOLEDocumentLinkObject)
		MessageBox.Show("DWG CREADO EN LA MISMA RUTA", "COMPLETADO")
	End Select
Replies (0)
