Inserting a part into an assembly
Message 1 of 10
Hi all could anyone point me in the right direction in regards to inserting
a part into an assembly as far as i can gather it is the Add Component
Occurrence Example in the API help is this correct or not.
Thanks Wayne
Replies (9)
Message 2 of 10
Wayne,
That's the right method. Take a look at the sample titled "Add Component
Occurrence" in the online help. It demonstrates this method.
-Brian
"Wayne" wrote in message
news:AC245102E99AD48F43FCCAC2E75F01EE@in.WebX.maYIadrTaRb...
inserting
> Thanks Wayne
Message 3 of 10
Thanks I thought so but i keep getting activeX cannot create component
errors do you have any ideas
"Brian Ekins" wrote in message
news:C687929EB83FF829920516689F374DC0@in.WebX.maYIadrTaRb...
> Wayne,
> -Brian
> inserting
> > Thanks Wayne
Message 4 of 10
If i copy and paste the code from the example Add Component
Occurrence into VB why do i get an error message what am i doing wrong it
says ActiveX cannot create
component.
Could someone point me in the right direction
Thanks Wayne
Message 5 of 10
Is the filename that's specified in the Add method correct? That's my only
guess at this point without having more information. There's another sample
you can try too. Run the AutoBolts samples that's delivered with Inventor.
There's small problem with that sample. Before you run it delete the file
in the "Bolt Library" directory.
-Brian
news:991FD35D63E6E232596EC1D8EB517361@in.WebX.maYIadrTaRb...
> component.
> Thanks Wayne
Message 6 of 10
AutoBolts didnt do the trick for me either but maybe you can tell me the
example from the API help file that uses the MSCal control is there info
missing from that doucment as it doesnt say how to actually add the control
to the prowser pane it seems to miss out a section of important info. ??
Wayne
news:D544F92783A1C2019A3BE139907C8B2B@in.WebX.maYIadrTaRb...
only
sample
Inventor.
> -Brian
it
> > component.
> > Thanks Wayne
Message 7 of 10
Wayne
I have tried that one before, and it worked fine for me. Not sure what could be going
wrong for you though?
Kent
news:D2E88C926A9FE935D91A974DADBF4DC8@in.WebX.maYIadrTaRb...
> Wayne
Message 8 of 10
It works from within IV ide but not from within a browser pane i have
programmed in visual basic
any ideas
Wayne
"Kent Keller" wrote in message
news:C090B45AE4CCA440201CAEC312CDAB47@in.WebX.maYIadrTaRb...
> Wayne
could be going
> Kent
control
> > Wayne
Message 9 of 10
The first set of code in the online documentation is incomplete. There was
a cut and paste problem. Here's the complete set of code for the Form_Load
function.
' Declare variable for the calendar control.
Private WithEvents oCal As MSACAL.Calendar
' Declare global variables for the Inventor document and Application.
Private WithEvents oDocEvents As DocumentEvents
Private oPane As BrowserPane
Private oApp As Inventor.Application
Private Sub Form_Load()
' Set a reference to a running instance of Inventor.
' This expects Inventor to be running.
Set oApp = GetObject(, "Inventor.Application")
' Get the active document. This assumes a document is open.
Dim oDoc As Inventor.Document
Set oDoc = oApp.ActiveDocument
' Connect to the documents events. Used to
' listen for when the document is closed.
Set oDocEvents = oDoc.DocumentEvents
' Create a new browser pane using the Microsoft calendar control.
Set oPane = oDoc.BrowserPanes.Add("Calendar", "MSCAL.Calendar")
' Set a reference to the calendar control
' that was created on the pane.
Set oCal = oPane.Control
' Set the calendar to todays date.
oCal.Today
' Make the new pane the active pane.
oPane.Activate
End Sub
-Brian
news:9197A3E6E0888B7B74BCD6C4351E3EBF@in.WebX.maYIadrTaRb...
> any ideas
> Wayne
> > Wayne
> could be going
> > Kent
the
info
> control
> > > Wayne
Message 10 of 10
Thanks Brian that was a great help i have managed to get that to work
Wayne
news:72FE06BC8CB5CDC2D67C4796560A29C7@in.WebX.maYIadrTaRb...
was
Form_Load
> function.
> oCal.Today
> oPane.Activate
> End Sub
> -Brian
> > any ideas
> > Wayne
> > > Wayne
what
> > could be going
> > > Kent
> the
> info
> > control
info.
> > > > Wayne
