Insert Title Block and border with iLogic code
Hi All
Im only new to Inventor. I have found a iLogic rule to import the title block from a template but it wont import the border I created in the template also. can someone please help
here it the rule that is working so far.
SyntaxEditor Code Snippet
Sub Main()
If ThisApplication.ActiveDocument Is Nothing Or ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
    MsgBox ("Please open a Drawing to work on.")
    Exit Sub
'reference template
ThisDrawing.ResourceFileName = "D:\Inventor\AWE Drawing.idw"
ThisDrawing.KeepExtraResources = False
Dim oDrawingDoc As Inventor.DrawingDocument: oDrawingDoc = ThisApplication.ActiveDocument
Dim SheetNumber As Integer
'Clear out the old Titleblocks & Sheetformats
For SheetNumber = 1 To oDrawingDoc.Sheets.Count
    oDrawingDoc.Sheets(SheetNumber).Activate
    If Not oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then
        oDrawingDoc.ActiveSheet.TitleBlock.Delete
Next SheetNumber
'Delete the previous title blocks as the API does not support replacing Sheet Formats.'DeleteSheetFormatsAll (oDrawingDoc)'DeleteBorders (oDrawingDoc)
DeleteTitleBlocks (oDrawingDoc)
Dim resu1t As String="Result"
Dim T1TLE As New ArrayList
T1TLE.Add("AWE Title Block")
resu1t=InputListBox("Select Drawing Title Block", T1TLE, resu1t, _
Title := "Title Block", ListName := "Title Blocks from Template")
    'Set iProperties based On the selection.
    If resu1t="AWE Title Block" Then
    ActiveSheet.TitleBlock = "AWE Title Block"
'    'End If
End Sub
Sub DeleteTitleBlocks(oActiveDoc As Inventor.DrawingDocument)
'Iterate through the collection deleting any titleblocks that are not referenced by the drawing object
Dim oTitle As TitleBlockDefinition
    For Each oTitle In oActiveDoc.TitleBlockDefinitions
        If oTitle.IsReferenced = False Then
        oTitle.Delete
    Next
End Sub
rikard.nilsson
Maybe I'm not understanding what you try to do but...
Here is a simple code for getting titleblock and border from a template (CopyFromDwg.dwg)
Of course you need to activate sheets in order to place them on the sheets..
But once you placed the new ones you can finish it up with delete every title and border that not is referenced..
ThisDrawing.ResourceFileName = "CopyFromDWG.dwg"
ActiveSheet.Border = "TestBorder"  ''Border in my CopyFromDWG.dwg
ActiveSheet.TitleBlock = "TestTitle"  ''Title in my CopyFromDWG.dwg
 For Each oTitle In ThisDrawing.Document.TitleBlockDefinitions
        oTitle.Delete
 Next
  For Each oBorder In ThisDrawing.Document.BorderDefinitions
        If oBorder.IsReferenced = False Then
        oBorder.Delete
 Next
Regards
Rikard
danmachen
Hi there,
Just a simple question, why do you want to import the border and title block from a template using iLogic?
You can create custom drawing and title blocks within Inventor. i.e. If you want to work with two different templates and two different borders, this is easily done naturally through inventor. New drawings can be created against your template every time a new drawing is opened
See my attached image.
Dan Machen
Ideas that need support:
Circular / Rectangular Point Matrix
Allow Axis & Plane Selection on Rectangular / Circular pattern
Graphical iLogic Programming
