Insert ipart from listbox
jplujan
jplujan
Hello I hope that they can help me:
I have listbox that shows ipartname of one ipartfactory it would like and me that when selecting one of them it could send to the assembly ipart selected hear show code.
Dim InvApp As Inventor.Application
Set InvApp = GetObject(, "Inventor.Application")
Dim IpartSeleccion As ipartMember
Set  IpartSeleccion = listbox1.Value
Dim oDoc As AssemblyDocument
Set oDoc = InvApp.ActiveDocument
Dim oOccs As ComponentOccurrences
Set oOccs = oDoc.ComponentDefinition.Occurrences
Dim oPos As Matrix
Set oPos = InvApp.TransientGeometry.CreateMatrix
Dim oStep As Integer
oStep = 10
Dim iRow As Object
iRow = listbox1.Selected
' Add a translation along X axis
oPos.SetTranslation (InvApp.TransientGeometry.CreateVector(oStep, oStep, 0))
Dim oOcc As ComponentOccurrence
oOcc = oOccs.AddiPartMember("C:\Temp\Abarcon generales.ipt", oPos, iRow)
MsgBox (listbox1.Value)
 Thanks in advance
jplujan
Hi:
As I can look for the name in one iparfactory?
Set oOcc = oOccs.AddiPartMember("C:\Temp\ipart.ipt", oPos, ["membername & " = " & selectedvariable"])
Dennis.Ossadnik
Autodesk Support
Autodesk Support
Hi jplujan.
The property "Selected" returns a Boolean if a specific row is selected or not. (It does not return the row (as Long) which is selected)
If your list is filled with the exact names of the members you could use it this way:
Dim SelectedMember As String
SelectedMember = listBox1.Value
Set oOcc = oOccs.AddiPartMember("C:\Temp\Abarcon generales.ipt", oPos, SelectedMember)
Hope this helps.
Dennis Ossadnik
Senior Technical Support Specialist
jplujan
Thanks for the answer, in the end I believe I have solved that it putting in listbox the index of the row and passing this one to the commando to insert, not if it could cause some problem to me
Private Sub button1_Click()
    ' Open the factory document invisible.
    Dim oFactoryDoc As PartDocument
    Set oFactoryDoc = InvApp.Documents.Open("C:\Temp\Abarcon generales.ipt", False)
    ' Set a reference to the component definition.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oFactoryDoc.ComponentDefinition
    ' Set a reference to the factory.
    Dim oiPartFactory As iPartFactory
    Set oiPartFactory = oCompDef.iPartFactory
    ' Get the number of rows in the factory.
    Dim iNumRows As Integer
    iNumRows = oiPartFactory.TableRows.Count
    oStep = 0#
    Dim irow As Integer
    For irow = 1 To iNumRows
        oStep = oStep + 10
        Dim nombre As String
        nombre = CStr(oiPartFactory.TableRows(irow).MemberName)
        Dim elementos As Variant
        Dim indice As String
        Dim fila As String
        elementos = Array(irow, oStep)
        indice = elementos(0)
        fila = elementos(1)
        listbox1.AddItem (irow & ";" & nombre)
    Next
End Sub
Private Sub Button2Click_Click()
        ' Get the active assembly document
        Dim oStep As Double
        oStep = 10#
        Dim SeleccionIpart As Integer
        SeleccionIpart = listbox1.Column(0)
        'Dim nombre As iPartMember
        'Set nombre = oCompDef.iPartMember.Row
        Dim oPos As Matrix
        'Add a translation along X axis
        oPos.SetTranslation InvApp.TransientGeometry.CreateVector(oStep, oStep, 0)
        Set oOcc = oOccs.AddiPartMember("C:\Temp\Abarcon generales.ipt", oPos, SeleccionIpart)
        MsgBox ("Ipt inserted")
End Sub
