insert frame command
in my inventor,i can't select line in insert frame.can you tell me setting to select line in frame?..
EScales
Are using this setting?
in my inventor,i can't select line(which draw in sketch) in insert frame.can you tell me setting to select line in frame?..
i have set as per your msg but i can only select part edge.i cant select line which i have drawing in sketch..
