Insert a positional representation in the order that I want.
I have an assembly model template of a machine.  I represent the various positions of the machine components with positional representations, displaying the positions through various points in the machine cycle.
If I use the template, and want to insert a new positional representation that represents a point mid way in the cycle, I'd like to be able to insert that positional rep in its proper stage in the cycle.
When I simply add a positional rep, it goes to the bottom of the list and cannot be moved up manually.
I see that the positional reps have an index associated with each one, but they appear to be read only.  Is there a way to access/modify them thru the API? Or is there another means of controlling the order in which the positional reps appear in the browser?
k14348
Hi @Anonymous
               Have you tried excel based positional representation to solve your issue. Ref image attached.
-Karth
Yes, but it still enters them at the bottom of the list, even if I insert a line into the spreadsheet.
