Including multiple components in a pattern
SharkDesign
Mentor Mentor
SharkDesign
I'm using the function
Patterns.AddRectangular
the help file describes parentcomponents as plural.  Does that mean I can include multiple parts here, or is it referring to plural only if you're patterning a pattern?
If I can add multiple parts in this single line of code, how do I do it?
Dim rectPattern = Patterns.AddRectangular("RectPatternName", "ComponentA:1", 3, 1.5 in, Nothing, "X Axis", columnNaturalDirection := True, rowCount := 2, rowOffset := 1.0 in, rowEntityName := "Y Axis", rowNaturalDirection := True)
  Inventor Certified Professional
dutt.thakar
@SharkDesign
Yes, you can include, see below an example code, where I am adding multiple components in a pattern. You need to use  "{" brackets.
Patterns.AddCircular("Pattern Name",{"ANSI-Washer-01", "ANSI-Washer-02", "ANSI-Bolt-01", "ANSI-Nut"}, 6 ul , 360 deg / 6 ul,{"ABC", "abc"},"Y Axis")
Also to get the syntax right, I would suggest you create a pattern manually and then go to iLogic, right-click the pattern and click on Capture current state(Patterns. Add) to get this always correct. see below snap.
Hope this will help you.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
SharkDesign
Ahhhhhh, it was the {} that I was missing, thanks a lot!
I did try the patterns.add but nothing happened. It works on the add.constraints ones, but the pattern ones never work for some reason.
