Include/Exclude
Include/Exclude
rjay75
Include/Exclude
rjay75
In iAssemblies how can you check the status of an occurance to see if it's include/exclude. And how do you get the Factory name of an occurance to do Table Replace.
I'm generating iAssemblies/iParts. A problem I have is that when a factory is created the values of the default row is overridden if they don't match the documents current value. To get around this I've use the values in the Factory table to 'reset' the document values to match the table before updating. This works fine on iParts. But on iAssemblies I can't find an Include/Exclude property. What controls this?
I face a similar problem.
In an iassembly of mine, i have a various number of occurences.
With an extrusion command (modify assembly) I cut of bits of the first and last occurence.
The first occurence is included in all members in the factory scope, but not the last.
It's possible to add participants to the extrusion feature (when right-clicked in the menu).
but the choises are lost, when im changing the members.
please reply if you have found a solution
best regards
Kristjan Geirsson
